Question about Viking DDSB483 Side by Side Refrigerator
Unit has custom door panels(wood) and handle is loose.I cant figure oit how to rmove panel to tighten handle
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Loose door handle
Here is the link to the installation manual; http://www.bshextranet.com/files/techtoolbox/SHV46C13-SHX43Cii.pdf pages 14 and 9 of the manual (16 and 11 of the pdf) describe how to remove the toe panel, and the door facia panel. You should then be able to access where the handle is attached. Hope this helps :)
Jul 15, 2007 | Bosch SHV46C03 Built-in Dishwasher
Loose handle
Open the door and loosen the self threading screws around the sides of the inner door panel. Once this has been achieved lift the inner panel up so that you can access the door handle screws. Tighten these fasteners and reassemble the door panel.
Jan 24, 2014 | LG LDF6810ST Stainless Steel Built-in...
Can not get rear passenger door panel off
there should be a screw behind the handle to open the door and a few more behind the wood trim panel. then the panel pops off.be sure not to loose the gaskets that are on the retaining clips.the wood trim pops off too. be careful. the wood is delicate.the shade assy should bolt to the inside of door not interior panel.
Jun 30, 2012 | 2005 BMW X5
2005 buick lacrosse Outside passenger door handle is loose, how do i tighten ?
The handle may just be loose but i have seen some that are broken and not loose but inorder to find out or to tighten it you will need to remove the door panel. the removal of the door panel can get tricky as there are hidden screws, you will need to locate them look around, there may be screws behind light and under window switches and on handle used to close the door then after they are removed the door panel comes off one of two ways, you will need to pry the bottom out a little and look to see if it has plastic hook arms or pop in hardware, if it uses the arms them you pull up on door panel and out it comes if theres pop hardware then you will pull on door panel to pull off, you may need a retainer door panel tool to avoid breaking the panel. good day.
Aug 12, 2011 | 2005 Buick LaCrosse
The handle is broken how can it be replaced. it cannot be opened
if it cant be opened from either side( child lock is on...etc) then the only way to get it open ist to try and rmove the inside door panel without breaking it< which is pretty much impossible. once you get into the door panne you can open the door by pushing the rod that used to connect to the handle. cheapest rout is to find a door panel and a door handle at a junk yard
Jan 18, 2011 | 1996 Ford Contour
The driver's side outside door handle is loose, toyota celica '95
I assume that the entire handle unit is loose in the body work of the door.
The interior door trim will need to be removed to access the inside of the door to fix the loose handle.
Do not attempt his yourself unless you have some experience in this area.
Take the vehicle to the nearest reputable auto body repair shop and they can easily fix it for you. There could be a breakage on the retaining system on the handle or the retainers may just need tightening.
Typically door handles which have not been subject to damage or abuse will not usually loosen like this. It's possible the door was damaged and the panel repaired and repainted at some stage. If so the door handle may have been removed and refitted in a sloppy manner.
Dec 03, 2009 | 1997 Toyota Camry
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Remove right rear door panel
  1. Remove the rear door power window/power door lock switch
  2. Remove the door handle bezel. Remove the door trim panel screw located behind the door handle bezel.
  3. Remove the door trim panel screws located by the armrest handle.
  4. Remove the door trim panel using J 38778.
  5. Disconnect the electrical connectors.
  6. Remove the door trim panel from the door.
INSTALLATION PROCEDURE
IMPORTANT: Discard the old door trim panel retainers and replace with new retainers before installing the trim panel
  1. Install new trim panel retainers to the rear door trim panel.
  2. Connect the electrical connectors.
  3. Align the door trim panel retainers to the door.
  4. Press the door trim panel at the retainer locations until the retainers are fully seated.
  5. Install the trim panel screws. Tighten Tighten the door trim panel screws to 2 N.m(18 lb in) .
  6. Install the power window/power door lock switch
Nov 04, 2008 | 1998 Oldsmobile Intrigue
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Viking DDSB483 Side by Side Refrigerator Logo
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Audie Bogus
Audie Bogus
Level 1 Expert
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
