Question about ASUS Eee PC 1000H Laptop
Blue power cord light is on, but computer does not power up or charge battery.
    Scholar:
  • 92 Answers
you can try the following:
  • Remove the battery and connect just the AC adapter and try to boot up. If it works then install the battery, if not
  • Remove the battery and AC and press the Power button for 30 sec
  • Under the netbook, ( when turned upside down) on the right-side near the windows key sticker you will see small hole use a pin to press this button. This will reset your HW.
First 2 solutions worked for me. I had issue with my battery calibration. After leaving it 24h on the AC all back to normal.
Hope it helps
Posted on Oct 04, 2010
  • amytournasha Oct 05, 2010
    Thank you for your help! I will give this a try. Much appreciated. :-)
  • Rui Oct 05, 2010
    Please feel free to leave you thumbs (vote) up on the post if you find this answer was useful...
    If you need more help just let me know.
5 Suggested Answers
  • 41 Answers
SOURCE: MY LAPTOP WILL NOT TURN ON
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
If this doesnt work can you hear any fans or hard disk activity when you press the power button?
Posted on Jan 20, 2009
stif_NEC
  • 441 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
If your system won't boot up with just the AC adapter connected, it means to say that there's a problem with the AC adapter or the motherboard of the computer. Basically, if the AC adapter or the motherboard is damaged, you won't get a charged battery. If there's another AC adapter that you can try your computer with then that will be great. If antoher AC adapter works, then you just have the AC adapter replaced. If a known AC adapter didn't work then you may need to consider replacing the motherboard of the computer.
Posted on May 07, 2009
  • 181 Answers
SOURCE: Battery will not charge/ keep computer on. laptop
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Posted on Feb 13, 2010
  • 84 Answers
SOURCE: packard bell easy note tj65 will not power up
try to remove baterry
Posted on Mar 07, 2010
Hp pavalion dv6550 runs on charged battery but not on adapter and does not charge the battery either. When the AC adapter is connected the blue light comes up so I'm assuming it is powered and con
Try another cord/charger with the EXACT same power specs as the original. Has the AC jack in the laptop been damaged, loose connection, due to pulling on the cord while plugged in? Try to wiggle it when plugged in to see if there is any connection. The AC jack may need replacing, if your lucky.
Apr 07, 2013 | HP Pavilion Computers & Internet
My nv79 notebook charges up my battery to 100% the charge light turns blue and after 1 minute cuts off and requires restarting to start charging again
Try removing your battery and power on your computer with your power cord only. If you have no problem with the power cord alone, then you need to replace the battery.
I hope this helps!
David
Apr 02, 2013 | Gateway NV7915u Notebook
Dell latitude won't charge
The internal battery may need replacement, especially if you have had this Notebook for several years
Mar 22, 2013 | Dell Latitude D600 Notebook
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
Aspire 1 laptop won't turn on but the light bulb
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Acer Computers & Internet
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
Let the battery power down, plugged back in and now computer will not come on at all, took battery out, nothing, not even the little battery flash light, even tho power cord in and blue light around cord
Need to check the power cord to see if it is running at 19.5 fisrt. The power cord may be your whole problemand it cheaper than the other problem I see.
If power cord is ok take battery to the battery store to check it's cells. it sounds like to battery is bad. but the power cord should still bring the unit up. If the battery is ok and the power cord checks out the charging unit is bad and is costly.
Dec 07, 2009 | HP Pavilion dv9000z Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
ASUS Eee PC 1000H Laptop Logo
271 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
