Question about Refrigerators
I have a maytag side by side. Ice maker was working fine then just stopped producing ice. The white hose....(looks like little vents thru it) is it suppose to connect to something? I moved it around and not sure if I broke it away from something. Right now it just hangs thru a white bracket but I see no water. Or where the water is suppose to go. I mean I see where the ice is made but don't know how exaclty the water gets to where? I looked in back of refridge and nothing seems to be kinked.
    President:
  • 1,099 Answers
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Take care....
Posted on Oct 04, 2010
Red light flashing i push tab on the left hand side light stop flashing ice in the maker but dont fall
If the ice has not been used for some time it becomes frozen solid, defrost it and all should be ok.
Apr 18, 2016 | Maytag 25.6 Cu. Ft. Side-by-Side...
Since putting my Christmas turkey and ham in the frig, it has stopped cooling. I've thought the heavy load and maybe blockage of the ventilation was the cause. I've removed everything and investigated. ...
ertet
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
your refrig side will be warm or ice at the vent..
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 25, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My ice make bin is full but it's not dispensing ice cubes.
their is a wire like arm that is on the side of the maker this tells the maker to stop making ice till the ice goes down you will need to remove some if the ice and then reach in and pull the wire arm down not hart you will feel it click and stop and is a couple mins it will start making ice again if this is not the case the ice unit could be frozen in place and you will need to thaw it out then see if it works if it still does not then it will need to be serviced hope this helps
Aug 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Oct 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
