Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
  • 382 Answers
Dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Posted on Oct 04, 2010
Why wont my black and decker 7.2 lithium drill take a charge ?
Did you check if the battery holds the charge? Also, you should verify the charger's output with a voltimeter.
Oct 26, 2015 | Black and Decker USA Black & Decker...
How do I re-charge by Black & Decker 12v cordless drill?
If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
Oct 04, 2014 | Black & Decker 12v Cordless Drill/driver...
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
Nov 19, 2011 | Black & Decker 18 Volt Cordless Drill...
I bought a Black & Decker 7.2v cordless drill with
Just charge battery put bit in and your ready to go.
Jul 04, 2011 | Black & Decker Drills
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
Black/Decker 12 v drill charger will not charge battery. help
If the battery gets warm after being in the charger a while and still is not charged, then the battery is bad
if the battery stays cool in the charger then the charger may be bad
Chargers usually have a light code, I.E. on means charged, slow flashing means charging, and a quick blinking means bad battery
Some chargers have 3 lights and the code should be imprinted on the charger.
hope this was helpful, cb
Apr 15, 2009 | Black & Decker Drills
this one dosn't charge. It takes batterys. how do i change them
Dec 20, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
395 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
