Question about Skil 108v Evo Drill And Driver Kit 241001
It worked great, then in a moment, a small amount of smoke emitted from the Skil 10.8v drill and it ceased to operate (although the integrated light at the base of the handle still works fine).
  • madmolly931 Oct 10, 2010
    Thank you for sharing your experience and knowledge bass. This drill has been tremendously useful for my applications and desire the return of its wide spectrum of use and utility.
    Could you tell me if it is cost-effective to replace the motor? If so, where would I go about to obtain a replacement motor and then how might i go about installing the motor in my old Skil 10.8v drill myself?
    once again, thank you.
    can you tell me where i can locate a replacement motor and also how I would go about installing it?
    New Friend:
  • 107 Answers
Your motor is gone. same thing has happened to me a few times.
Posted on Oct 10, 2010
How do I know when my 10.8 skil drill is fully charge
The charging light should go off when fully charged. Usually takes about an hour.
Aug 29, 2017 | Skil Drills
Makita instructions
Get the battery tested. The light draws a very small amount of power and will work if the battery is just about dead, but to operate the drill, you need a strong battery.
Jul 27, 2014 | Makita 18v Lxt Li-ion 1/2-in Hammer Drill...
My 2000 Sebring convertible has begun to overheat, buck, and knock loudly. There wa a small amount of smoke emitted from under the hood. Water light also went on bkut oil and water were both OK. Wh
SEEMS THAT U HAD A PROBLEM WITH THE RADIATOR.WATER ON IT CAN BE A BAD LINE OR IN THE WORST CASE THE HEAD BLOCK.OVERHEATING CAN DAMAGE THE HEAD SEAL AND START LEAK WATER.ALDO THE TRANS USE A COOLER SYSTEM INTEGRATE WITH THE RADIATOR.
Apr 11, 2012 | 2000 Chrysler Sebring
18V Litiom Batteries (Skil)
I would return it and tell them that the battery wont work.
Mar 02, 2010 | Skil 18V Lithium Ion Drill/Driver Model #...
Charged it and it stopped working
Here is the link to Skil. http://www.skiltools.com/en/CustomerService/ServiceCenters/
Call them and see what they recommend that you do. They will want to keep you as a valued customer. Regards, Joe
Jan 25, 2010 | Skil 2362 02 7.2 Volt Lithium Ion...
Describe your Dewalt & 14.4V Xrp
Hello. I can help you. Your motor is producing the smoke. Before more damage is done I recommend taking it or sending it to a Dewalt sercive center.
Jul 02, 2009 | Dewalt & 14.4V Xrp Hammer Drill
Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Jun 10, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Dec 19, 2008 | Drills
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
Skil 108v Evo Drill And Driver Kit 241001 Logo
76 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
