Question about Home
Manual for redmont jucuzzi - Home
1994 jucuzzi high speed jets dont work ?
If the motor is not going to high speed then you have one of two things happening...
The relay for the high speed is not working right or the high speed is burnt out on the motor...
Check the high speed connections in the motor for power... if you have power it is the motor... if no power there then the control is bad...
heatman101
Sep 26, 2011 | Jacuzzi Allusion Whirlpool 7242 w/2 Speed...
How do you get the pump out of the housing on a jucuzzi magnum force pump
If yours is the model with the big round ring around motor, it is a large retaining nut. Remove this nut and the motor should come from the pump housing. Don't be too rough, plastic breaks.
Jun 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My temperture on my hydro bath seems to be faulty
TIME TO REPLACE SORRY TEMP GAUGE NOT BATH BEST OF LUCK
Oct 08, 2009 | Water Heaters
My Laars will turn on. Was waming jucuzzi then stopped and won't turn on.
it got hot and this means it did not have the right amount of water flowing trow the Heather is was less than normal causing the heather to get to hot and the high limit switch kick the heater off other mayor problem is with the temperature sensor located right in the heather outlet line make sure your filter is clean most problems occurred because the filter get dirty
Jun 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jacuzzi tub on/off bezel wont hold switch down
I couldn't find the information you are asking for in the installation manual. I have included a link to the pdf page so you can print it out and look at it in print. On this particular question, I think I would give Jacuzzi a call. They can better answer you question without guessing.
http://jacuzzi.com/pdf/K272000.PDF?SELINSTMANS=K272000.PDF&goinst.x=15&goinst.y=8
Mar 22, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jucuzzi era bk 37 959 just installed 6 weeks ago , I have to use
when it was installed the wax ring was most likely installed wrong or has moved and is blocking drain it cost 5 or 6 bucks to replace. thank you for for useing fixya please rate me
Feb 26, 2009 | Jacuzzi Bath Era BK37 959 White toilet...
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Feb 15, 2009 | Jacuzzi Pool & Spa
Home Logo
121 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
