Question about General Hand Tools
Where can i get a tilt bracket for my rlt26cds attatchment hedge trimmer
You actually buy a different head cutter, that has the angled attachment already built in,
Posted on May 10, 2011
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
Why does my kawasaki hedge cutter start easily but stop when tilted at a certain angle
ummm, because the fuel pick up is not in the fuel. I bet it is ok when the tank is completely full right?
Sep 19, 2014 | Garden
Why does my kawaski khs750b hedge cutter start easily but stop when tilted in a certain position
Answered your own question : generally the fuel supply to the motor is through a small hole at the base of the tank , at full you could probably tilt more aggressively and the line is getting fuel , however as the fuel runs down the fuel is on one side of the tank and is essentially not getting fed to the motor , you'll notice tilting it from horizontal to left you will get cut off , tilt to right it'll keep running depends on the locations of fuel line however , cars pre fuel pump days had similar problems
Sep 19, 2014 | Kawasaki Outdoor New kawasaki Hedge...
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
1984 B&D double sided hedge trimer stops and
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
Jul 28, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Hi I recently bought a Ryobi RLT26CDS. Every time the thread needs extending I have to undo all the gadget and manually pull and extend the thread. could you please tell me how I could extend the thread...
'Bump' the strimmer line unit on the ground (this is how it releases the line)-It sometimes gets stuck(welded to the sides if the release chamber-it gets hot and melts)-
hope this helps
Jun 07, 2010 | Ryobi Garden
My stihl hedge trimmer bogs down when tilt on its side. why
Metering diaphragm in the carburetor is weak. It is going to need a rebuilb.
Has any tune up work been done on this unit lately?
Sep 24, 2009 | Garden
Hand Tools Logo
48 people viewed this question
Top General Hand Tools Experts
Bill Boyd
Are you a General Hand Tool Expert? Answer questions, earn points and help others
