Question about Watches
Gucci watch 19 years old had battery changed and glass now full of condensation when I wear - clears up when not worn?
  • 831 Answers
Thank you for contacting FixYa.
After a battery is replaced, some watches require new gaskets, or O rings, etc to keep the watch water resistant. Prob the case with your watch. I would check with a qualified local watch repair or try Gucci at following link:
http://www.gucci.com/us/assistance/assistance
Best regards. Jewel
Posted on Oct 05, 2010
I have a Gucci watch which cost £630.00 and the battery lasted 17 months, is that the usual life span for a battery
it can be--their is no definite life span of a battery because everything has a different draw of power a simple watch can last years while more complex such as date/stop watch /backlight etc will draw and kill battery quicker
Jul 19, 2016 | Gucci Watches
New Gucci watch is not running, will taking off the plastic film with the red strip on the back make a difference.
That decal/sticker is usually only an indicator of a un-worn watch.
The only thing that will turn the battery on is pushing in the STEM.
If it does not run then... your battery SHELF LIFE has been
exceeded... Time to get a new battery
https://www.gucci.com/us/en/st/faq
Gucci offers a repair service for Gucci products purchased from Gucci.com, ... Watch Repairs* East coast: GTS 50 Hartz Way Secaucus, NJ 07094 tel 1.866.692.8244
Gucci Gucci
Dec 14, 2015 | Gucci Watches
Why does my Gucci watch quit running every few days?
You can start by fitting a new battery & monitor it &see what happens good luck
Aug 20, 2014 | Watches
Rolex Sumariner with Date submersible to 300metres
your submariner is an automatic movement that needs to be serviced every 3-5 years to replenish the oils and to stop any wear or tear on the movement the regulation is part of the service
Apr 16, 2014 | Rolex Watches
How to clear condensation
when you changed the battery did you replace the rubber seal on the back plate if not that's why you have condensation in your watch,dry off with hair dryer and replace seal ,then it will be ok...
Nov 19, 2012 | Garmin FR60 Wrist Watch for Men
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
Glass broken. is the glass available and how much? and approx cost of fitting new glasss? TIA.
mcdevito75 here, Approx. $125.00, look for a small watch repair shop in your area to save money, Most likely crystal will have to be ordered from Gucci.
Jul 16, 2010 | Gucci 1500 YA015512 Watch
Gucci watch looses 10 mins a day after battery change
Please refer this matter to expert. Kindly run through below website for assistance in finding the nearest outlet/dealers in your country.
Gucci
Apr 12, 2009 | Gucci 6700 YA067503
Watches Logo
305 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
