Question about GE Security Simon 3 Wireless Home Security System
Trouble light on key pad
The trouble light is on and at 2:15 every night an alarm goes off. How do I turn this light off?
I recently purchased a 99 pontiac bonneville...was playing with light switches trying to figure out what goes where...after exiting and locking with door lock i noticed the interior lights still...
If you don,t have the remote for the (Alarm) Try end get one for it, Or Have the alarm taken out if it isn,t a factory installed (Alarm)
Nov 07, 2012 | Cars & Trucks
2006 buick alarm can not be shut off.....
After the key is put into what? The OEM alarm is armed and disarmed through the driver's door key cylinder. Insert the key into the key hole of the driver's door, turn to unlock, this disarms the factory alarm. Turn to lock, this arms the factory alarm. Now, if you have an aftermarket alarm this procedure does not apply.
Oct 07, 2012 | 1998-2002 Park Avenue Door Lock & Alarm...
Had the alternator replaced 2 days ago and during the night the alarm goes off lights flashing honking use the key fob to turn it off and takes a while for inside light to go out stays quiet for a while...
Hello, sounds like you need a new battery. As the battery goes flat the alarm senses it and sets off the warning system. Try changing the battery first and test it during the day. Also check to see if there is anything draining the power. You may also be able to adjust the alarm settings manually. Failing that, the alarm may need replacing. I hope I have helped.
Mar 24, 2011 | 2003 Chrysler PT Cruiser
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
2005 Dodge Dakota alarm and key pad trouble
No i do not think you have electrical problem, try this.
Car in Park
Key on
push and hold unlock on good remote for 5 to 10 seconds
while holding unlock, press and hold panic, then release together
Listen for chime
press and release any button on all remote to be programmed.
If this will not work you need to bring the Vin# and remote to a dealer for reprogramming.
Aug 09, 2009 | 1997 Dodge Dakota
When i turn on my laptop the alarm bleeps for about 20 seconds, then the alarm goes off also having trouble with the backspace and enter keys, plus the touch pad does not work. all this has roughly...
has the laptop been dropped or gotten soaked by some fluid. sounds like something has infiltrated down to the laptop motherboard. Time for a new laptop, or some shop time
Jul 11, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
Electrical Alarm
TSSM or Turn Signal Security Module is more than likely the cause. Look to see if key and or eng light in instrument cluster comes back on after initial 4 second pwr up goes out. The key light coming back on for ruffley 8 seconds and then off shows historical trouble code has been logged in ECU. must take to shop to clear codes.
Feb 08, 2009 | 2005 Harley Davidson FXSTD - FXSTDI...
97 honda civic - all lights inside & hazards blinking
sounds like a short in the alarm system
usually alarms will blink all lights when the alarm goes off
need to check the system with a scanner
Nov 07, 2017 | Honda Civic Coupe
GE Security Simon 3 Wireless Home Security System Logo
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
