Question about Sharp MD-MS702 Personal MiniDisc Player
MD Error Message
I have a Sharp MD recorder. when I press record I get the message
Toc W Error I've mislaid my manual, can you tell me what that means
Thanks Richard
  • darrendowlin Feb 17, 2009
    I'm looking to purchase a add on battery pack for the sharp 702 mini disc player, can anyonw point me in the right direction?
I'm sorry this isn't much help, but I had the same problem with my 702 unit. From what I've read it's very common with this model - Sharp claims to have remedied the error with their 831 unit. Luckily, when I had this problem, my recorder was still under warranty and I have to say that Sharp fixed it promptly and returned it to me. Have you tried contacting them? Since it's a design flaw, they might be amenable to working something out with you...
Posted on Oct 25, 2008
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:!topic/!
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Pc minidisk
Google sharp MD-MT280E and download the Users Manual.
Aug 08, 2013 | Sharp MDMT280E Personal MiniDisc Player
SONY MDS JE 530. (C14) Toc error.
You may well be right. Try a different brand of disc.
Apr 01, 2013 | Sony MDS-JE330 Mini Disc Player
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
I've been sent a recently recorded 80 minute Sony Minidisc - but when I attempt to play it, a 'TOC Error' message is displayed. I suspect the disc was ejected from the machine immediately after...
Your diagnosis is likely correct and yes, you can save the data by a process known as TOC cloning.
Depending upon the make and model of your MD recorder(s) you may have to obtain a TOC-cloning friendly model, but every single piece of MD equipment I own has come for free via FreeCycle or Gumtree so you shouldn't have any problems in that respect. If you need one in a hurry then they're usually dirt-cheap on ebay.
I don't wish to plagiarise, nor is there any point in re-inventing the wheel, so if you click here you'll see detailed instructions.
Good luck. Sorry for the long delay in posting an answer,I have only returned to FixYa last week after a long absence and this section isn't often monitored by others as questions are rare now that it's obsolete technology.
May 13, 2011 | Audio Players & Recorders
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
MD-MT831 MiniDisc Recorder Error
I've run into the same issue. Have you got it solved yet? In such case, could you please share the solution here? I've tried to enter service mode but with no luck.
May 26, 2010 | Sharp MD-MT831 Personal MiniDisc Player
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Toc error problem
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Sep 20, 2007 | Sharp MD-MT20 Personal MiniDisc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
703 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
