Question about Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90. My printer will not feed the paper through. It seems like it is trying but then it stops and makes a strange grinding noise. Anyone know what this is all about or how to fix it?
  • 24 Answers
SOURCE: canon ip90 printer
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
Posted on Jan 22, 2008
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
graysand
  • 558 Answers
SOURCE: Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Posted on Aug 28, 2009
  • 979 Answers
SOURCE: Canon PIXMA MP160 Printer is making a grinding
Good day sir/maam, the gear on your printer that holds the print head/ink is stuck, loosen it by applying oil or contact cleaner, check your local dealer if they have warrantee for your printer. If you really want to do the repairs yourself the service is like this.
  • open the printer, and check what is causing the grinding. usually mechanical elements are involve.
  • remove dirt and clean the ink spill.
  • loosen the print head/ink, apply oil and contact cleaners.
  • check the contacts and connectivity of the mechanical parts with the main circuit board.
  • test parts and if needed, replace it.
  • test and retest. do everything again until the printer works.
Hope this may help, its kinda dirty but saves you money for service.
Posted on Sep 28, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
How to clean roller
I suspect your ip90 is suffering from the paper feed fault. Has a spring fallen out? Getting it back in is a nightmare in fact other than changing heads on the ip90 everything is a nightmare. In most cases the either the paper feed assy needs changing or the print engine needs replacing. Its not cost effective on the ip90. Think about replacing it.
Jun 15, 2016 | Canon PIXMA iP90 Mobile Printer
Why does the paper jam and a loud noise come from the iP90 printer?
Most likelt to be a foreign object or wad of paper crammed into part of the paper feed roller. The first thing to do is turn it upside down and give a few sharp solid taps on the bottom casing. Then check to see if anything falls out. Also check the leading edge of the paper that didnt go through for marks that might show where it was stopped. If you are sure there is nothing to stop paper feeding through, check at each end of the print head path inside for a clump of ink soaked paper - remove if found. Try feeding a sheet through again. If the paper doesnt feed, try slipping a thin stiff card or plastic sheet back through the feed mechanism from the front. If that doesnt go through, you will have to disassemble the printer to find the problem.
Jun 27, 2014 | Canon PIXMA iP90v Printer
Ip90 printer makes a vibrating buzzing noise upon start up
something is obstructing the rollers.something such as an office pin or pen/cock or any other thing might have fallen inside.open the machine and clear the jam.
Dec 26, 2013 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP510 problem with j feed
Is mechanical problems,gears blocated,you must be remove the covers and look attent the transport drive mechanism components.
Feb 16, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Mar 12, 2008 | Canon PIXMA iP90 Mobile Printer
Paper in printer
Goto the link provided below. You will need to fill in the three drop down windows.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Select cateegory = Printers
Select product type = PIXMA iP Series
Select model = PIXMA iP90
Click GO
Start with Number,
1.) Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Continue down till issue is resolved.
Feb 12, 2008 | Canon PIXMA iP90 Mobile Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 InkJet Printer Logo
105 people viewed this question
old marine
old marine
