Air conditioning unit is spitting out water
I just put the unit in the window, it cooled down the room in about 20 minutes, and now its spitting out water.........can u tell me if this is something can be fixed, or maybe i need to do something...thank u for ur help sir/madam
    Genius:
  • 1,073 Answers
Unit need to be tilted to the rear as it is installed in the window for proper drainage of condensation water off of the interior coil
the fan on the rear will pick up the water and remove it
tilt it back a little
Posted on May 27, 2008
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I'm not sure if this is the same model I have, but
hi ' most of window type aircondition produces noise not same as the split type , but i see you have problem of the water that spits to your room, may be you can check the mounting of the unit, the proper mounting is it must be a little slant making the water run to its drainage . the edge of the casing must a little bit dropped lower in mounting.
Jul 11, 2011 | Goldstar LG L1004R Window Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Sears Plasmaire spits water into room
It's probably just holding water somewhere and getting thrown out. I've seen people drill holes on the bottoms to drain water quicker.
Sep 03, 2009 | Kenmore 75085 Air Conditioner
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
I just had two Kenmore 75251 24500 window units placed by pro installers into a large room well within the square foot rating, the units "spit" water droplets out of the cold air vents, the temp was 86 and...
you need to better balance the blower speed and the temperature setting until you get the air in that room conditioned to where there is not as much moisture. Too little air passing over the coils results in poor cooling and a tendency for the unit to frost up ------too much air passing over the coils too quickly results in poor cooling and poor dehumidification of the moist air
Jun 24, 2009 | Heating & Cooling
Frigidaire window unit spits water into room
To be honest with you this is a good and a bad thing. The bad thing is that it is spitting water into the room. The good thing is that the unit is running Great. The amount of humidity it is removing. is greater and faster than it can run down and off the coil. See if there is any possible way to deflect the water. i would recommend trying to attach a piece of screen door material. It will likely keep the water from going through it.
Dec 17, 2008 | Maytag M7D24E7A Air Conditioner
Heating & Cooling Logo
555 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
