Question about Carrier Beverage-Air UR30GEFD Beverage Cooler
I just bought a used UR30GE and it has no light bulb in it. What is the number of the florescent bulb I need?
Ceiling light (2 florescent bulbs) on ceiling, will not go on
I FOUND THE PART NUMBER FOR THIS GLASS. THERE ARE 2 OPTIONS, DEPENDING ON YOUR TASTE.
PLG 1200-187
PLG 1200-129
Dec 04, 2013 | Dryers
Tip
Money-Saving lighting hints
We are being sold on the idea of florescent lights saving money. Please consider that these bulbs use a much lower amount of power while they are on. Also, be aware that they will "burn" for a longer period (on average) than other illumination types (excluding LED lamps). HOWEVER, it is critical to your pocket book... to be aware of the following :
1. FLORESCENT lamps cost 5 to 10 times the price of an incandescent lamp.
2. ON-OFF cycles reduce the operating life dramatically (for example, a garage door opener that comes on/off several times a day and stays on for only a short period of time will NEVER result in a savings to you). Please use these lamps ONLY in fixtures that are left on for at least several hours each day.
3. The environmental impact of a florescent bulb is dramatically greater than any other lighting device.
4. The longivity claims of the bulb manufacturer are not worth the ink that those claims are made of. If you doubt this, ask the retailer if you can return the failed bulb if you get less than 5,000 hours of life (ha ha).
on Jan 28, 2010 | Computers & Internet
My viewsonic 17
most likely the back light is burned out. Since you do not mention the model number it is hard to tell if this uses a incandescent or florescent bulb.
Aug 01, 2012 | ViewSonic VX922 19" Monitor Flat Panel
Leviton 3-way wide view motion activated light control, flickers, then blinks then shuts off after installation. Installed in a hallway with florescent lighting.
Some switches are not designed to work with the florescent bulbs. It's a matter of them trying to push a starter for the light. Check the package and see if it's compatible.
Jan 06, 2011 | Leviton Electrical Supplies
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Superswitch programmable wall light switch - when timer is in off position lights glow dim when using energy saving bulbs.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Manual say 'incandescent' light bulbs only.
What can I control with my EJ351C? The EJ351C timer is to be used with standard base incandescent light bulbs only! It should not be used to control lighting such as:
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
Oct 16, 2010 | Intermatic Programmable 24 Wall Switch...
No video but i have sound what board should i need to replace?
If your power light is coming on and you can hear sound.It should be your inverter.The inverter works like the starter in a florescent light bulb.Your backlight isn't coming on. Try ebay by typing inverter and your model number in their search.
Nov 15, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Light does not come on when I open/close door, not the bulb
Good Morning:
I also substituted Floescent Bulbs for the standard bulbs. The bulbs would not light up although the relay was working. It seemed that the Florescent bulbs had a somewhat shorter neck. What I did was unplug the drive system from the outlet and then bend the metal connector in the socket so that it would come out further towards the opening of the socket. I then repluged the drive. The Floercent bulbs now have contact and are working perfectly. Simple problem with a simple solution.
Sandman
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs burn out after a few days in garage door opener, craftsman 1/2 HP double lights. have used every kind out there, specially made for garage doors, etc.
Try REVEAL brand DOUBLE LIFE ceiling fan light bulbs, available from HOME DEPOT. The filament in those bulbs is much thicker than any others, and the one I installed on my own Sears GDO has lasted 3 months so far, compared to one week for others I have tried.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Carrier Beverage-Air UR30GEFD Beverage Cooler Logo
189 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
