SOURCE: canon pixma mp560 gives error
This error indicates that there's an obstruction with the Carriage which is hindering the movement of the carriage. It's possible that there's something obstructing the following components: print path, the gears, or ink on the clear plastic encoder strip. Open up the front access door and check the printhead position. If it parks where it should, try moving it manually towards the other side, do this while the printer is On. After that, restart the printer.
If this doesn't help, then try the following steps:
If the problem persists, try reinstall the cartridges and the print head. Also clean all the (possible) components so that there shouldn't be no actual obstructions inside the printer.
If nothing seems helpful, you may likely need to service the printer.
Good luck
Thanks for using FixYa.
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
SOURCE: Canon Pixma MP560 Wireless horizontal lines when
well fix it so u can make the lines vertical u lazy piece
SOURCE: Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
