Question about Refrigerators
Whirlpoolrefrigerator I need help in order to remove ice dispenser on my Whirlpool Side by Side. I cannot find information in my manual. I really needs to be cleaned. Hazel Jackson
  • flower lady May 30, 2008
    We were unable to remove the dispenser. Do you have another suggestion?
    Thanks,
    Hazel Jackson
    President:
  • 1,314 Answers
Lift up on it and pull it out
Posted on May 27, 2008
  • robert samples May 30, 2008
    of course i can send me the model number is it on the shelf or in the door
25.2 cu. ft. side by side with ice through door: When I try to get ice through the door it will only despense when I push really hard and push up on the indoor depensing lever. I already took the ice out...
Ok unplug your box. go to the dispenser remove the tray. Now pull down on the bottom cover. this will unlock the cover. Right behind the cover is a plastic swtich holder. You have a broken pin that holds the swtich. replace this and you will back in order. hope this helps.
Aug 21, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
My son shoved a spoon into the icemaker bucket and it's jammed. Now neither the ice maker nor the water dispenser works. I have emptied the ice from the bucket and stopped it from making ice. I can see the...
My ice dispenser lever stopped working. I took the face plate off by first removing the tray, grabbing the bottom face plate and pulling straight back. I found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. I'm ordering a new bracket that holds the switches. Hope this helps.
also I found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. Bad bad design!
Instead, I replaced the pins with screws.... never coming apart again. Now how long before the Ice side breaks?!?!?!?!
I had this same problem.
Whirlpool Side-by-Side Model#: ED20DFXEB01
I removed the front panel from the water/ice dispenser - just to make sure the problem was not with any of the connections there. Just put a meter on the wires to verify current. All was good.
I pulled the refrigerator out and removed the valve assembly for the water/ice dispenser. Since the ice was working and the water was not, I simply swapped the connections on the solenoids. Sure enough, when I pressed the switch to dispense water, it came through the ice maker. Answer: bad solenoid on the water side...
I happen to live close to a commercial appliance store so I took the valve assembly (along with the model number for the fridge) over there and ordered a new one. $50 and 24hrs later, I'm good to go. In my case the part I needed was part# D7742204 (technically an Amana part but was the exact same thing) and it's a very easy part to swap out on my own.
If you are still curious as to how to remove the face plate... There are 2 small slots on the bottom of the faceplate. Pry out on those and the plate slides up and off from there.
Jun 10, 2010 | Whirlpool Refrigerators
My ice maker wont deliver ice. can you help
Ice maker/ ice dispenser manual HERE
If the ice maker mold is empty try adding some water. Wait. If a batch of ice pops out then water valve replacement is in order. If it fails to pop out a bit of ice then the ice maker is bad. I have more information on a page I created HERE
Jan 18, 2010 | Whirlpool Freezers
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How do I replac the clear plastic cover over the ice shute on the
order the chute assy old pull out and down holding the lever as to not break it other snaps in reverse order
Aug 19, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Dec 31, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser motor not working
try removing the ice bin from unit, try using dispensor now, can you hear it turning now??? if so empty your ice bucket possible frozen water on bottom of bucket preventing auger from turning
Feb 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
