Question about Praktica Cameras
Lens error e1111 ,2113 - Praktica Cameras
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Praktica service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
Lens error
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 03, 2011 | Nikon COOLPIX S200 Digital Camera
My camera say lens error 111000
Your lens problem is common defective. It need lens unit replacement or just repairable.
Try just some basic things first-just to make sure it's actually the lens that's broken. Replace the batteries with fresh ones. Failing that, replace the memory card.
Keep us updated.
May 31, 2011 | Kodak Easyshare C813 Digital Camera
Lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 14, 2009 | Canon Cameras
Jun 28, 2009 | Canon Cameras
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
250 people viewed this question
Top Praktica Cameras Experts
Greg Cann
Greg Cann
Are you a Praktica Camera Expert? Answer questions, earn points and help others
