Question about Whirlpool Duet GHW9150P Front Load Washer
"F-01 error after pushing start button - Whirlpool Duet GHW9150P Front Load Washer
  • 2,382 Answers
Hi, the technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Posted on Oct 04, 2010
2 Suggested Answers
  • 156 Answers
SOURCE: Washer did not start
if its only few weeks old call sesrvice on it the part underwarrenty in most cases 2 years
Posted on Feb 28, 2008
I have an IBM Think Pad type 2373. whenever I turn the computer on I get an error: 0210: Stuck Key 01 It says to press F1 to fix it, I do this and nothing happens. Can you please help me fix this?
F1 may appear as a secondary key on your computer. When the error message starts, try first pushing the 'Fn' key (near Ctrl), and then clicking the F1 button. Then you can follow your computer's instructions to fix the problem.
May 02, 2011 | Computers & Internet
SHARP PRINTER AR-M455N ERROR CODE H5-01 RESET
you probably got alot of jamming on the left side around the fuser. you will need to clear it in service mode. simulation 14. i believe it is c - * - p - * buttons you have to push then enter 14, start key, then follow directions
Sep 05, 2010 | Sharp AR-M455N Copier
Code F 35 i cant find my manual
christydubar --
Whirlpool Duet GHW91000 Technical Service Manual does list F35 error code. Try running the diagnostic test below and then write back with condition indication code. -- SWT
DIAGNOSTIC TEST
The control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the test mode
Close the door.
Press the Control On button.
Select the DRAIN/SPIN cycle.
Select NO SPIN by pressing the SPIN SELECT button, as needed.
Push Prewash Option button four (4) times within five (5) seconds. C:00 will show in the display.
NOTE: If Model does not have PREWASH Mode as an option, press RINSE/HOLD.
If the Starting procedure fails, push PAUSE/CANCEL button. Then repeat the starting sequence.
Test Program Control during Execution
To advance to the next step of the test procedure, push Prewash Option button two (2) times.
Indications
C:00
C:01
C:02
C:03
C:04
C:05
C:06
C:07
C:08
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 01 code comes on when trying to start another load. Pushed the cancel button and the machine shuts off also tried unplugging it and that does not work either
F1 error means a communication error, if you unplugged it, for more then 2 mins that should have work, but you also have to verify ccu operation by running a diagnostic test
Jan 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
Dec 28, 2008 | Dishwashers
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Aug 30, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
