Question about Microwave Ovens
I self cleaned my stove kenmore790.9532. It tripped the breaker in my basement. Now the oven doesn't work at all !. when I UNPLUG AND replug the latch motor buzzes real quick. Would it be safe to assume that the latch motor is bad.
    President:
  • 1,430 Answers
Pretty safe to assume. This commonly happens after self cleaning. Here is a link to your part Motor - Latch
You could double check by checking with an ohmeter. Connect one lead to each input wire the needle should move slightly or read less than 1 ohm. Also connect one lead to a single terminal and the other to ground, you should have no continuity. Check both leads this way.
Posted on Oct 04, 2010
I have a gold star above stove microwave model MV-1515B with the message 'LOCKED' showing on display screen.
Pic is a nice touch!
Have you tried depowering - unplug or trip breaker, whichever is easiest.
Jan 05, 2015 | Microwave Ovens
Freestanding stove (range) keeps tripping breaker when oven is used or two burners are used
Is this a new installation?? It sounds like the circuit breaker is under rated for this unit.
Nov 03, 2013 | Panasonic NN-H965 Microwave Oven
I have a Caloric stove of the prestige series with a self cleaning oven. How do you turn on the self cleaning oven?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 22, 2011 | Microwave Ovens
During the cooking for our Christmas dinner the temperature started declining from the 350 degrees to 280 degrees. We tried the top burner to make sure the stovetop was working and the whole thing shut...
Hi Jane,
Ouch! Sorry about the Christmas dinner. I sounds as though the circuit breaker tripped.
First, find the circuit breaker panel.
1 Check to see if a breaker has tripped. These breakers are double sided because stoves are
240 volt appliances, like the water heater or the house heater. There is a bar that connects
two single breakers together. The breaker will be slightly off center to the other breakers if it is tripped.
2 If it HAS tripped DON'T TURN IT ON YET
3 Go back to the stove and plug it in.
4 Turn on a top burner(not the one that may have tripped the breaker) preferably one that you know works that you don't use very much.
5 Go back into the garage and turn on the breaker.
6 If it goes on OK go back to the kitchen. You have done the first diagnostic test.
7 Check the burner to see if it is getting hot. If it is, turn it to high and then turn on the burner that blew the breaker in the first place. See if it blows the breaker again. If it does not. Turn on all of the burners that you know work. You have now done several Diagnostic Steps that are important.
8 If one of the burners trips the breaker, you have one of the culprets. If not, GREAT.
9 Shut off all of the burners
10 DO NOT TURN ON THE OVEN
11 Open the oven door and look very carefully with a flashlight at the bottom bake heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced.
12 There is one other rare possibility, but it would not have blown the breaker. Many ovens have clock baking timers. These timers will, shut down the oven. If someone adjusted the timer and didn't turn the knobs in the exact right position. It will ruin the party shutting down the oven at the worst time. But it won't shut the stove top burners down.
IF YOU HAVE FUSES INSTEAD OF BREAKERS
If you have fuses instead of circuit breakers, Find several of the large cylinder shaped fuses to conduct the diagnostic tests I suggest. They are usually available at home depot.
RARE PROBLEM
One last but very rare occurence with breakers is their specifications sometimes change over a long period of time. If that is the case, they will trip and lower and lower overload levels. Simply Replace.
I hope this helps,
Good Luck
Best Regards,
Mark
Dec 29, 2010 | Microwave Ovens
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
Stove lights
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
