Question about Singer 1507
My thread keeps comming out of the needle whenever I sew.
    Genius:
  • 1,788 Answers
Make sure that you have a long enough tail (3-4 inches) on your thread, and hold the tail until you get going for a couple of stitches. Ideally hold both bobbin and top thread ends for a few stitches.
Posted on Oct 04, 2010
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
I am using a finesse 356 sewing machine and the thread keeps on breaking off at the needle. What could be the problem?
Could be threaded wrong. Could be tension too tight. Could be a bad needle. Could be bad thread (avoid old thread or bargain bin thread). The fabric, needle, and thread may not be compatible, ie the thread is too large for the needle's eye, could be incorrect thread for the fabric, the fabric may be too coarse and is wearing the thread and causing it to break... There could be a burr or nick somewhere that is catching the thread. The thread could be hanging up somewhere in the thread path on the way from the spool to the needle causing it to break when it reaches the needle.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwi04JrRs-_NAhWKPiYKHaccBmwQFggzMAI&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
All About Needles Understanding of Sewing Machine Needles Coats Industrial
Why Does My Sewing Machine Top Thread Keep Breaking Howcast
Jul 12, 2016 | Sewing Machines
Singer sewingmachine how to stop thread from breaking on the top
Thread breakage is often caused by a burr on the needle. Whenever i have a problem with thread breakage, I unthread the machine, replace the needle, and rethread.
Sometimes thread will wrap around the spool pin, so I use the upright spool pin or use a mug or water glass to hold the spool upright behind the machine.
Jul 19, 2014 | Singer Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 15, 2013 | Sewing Machines
When sewing thread keeps breaking and comes out of the needle
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
Jan 08, 2013 | Yamata Sewing Machines
Morse zig zag mzz sewing machine needle cutting thread
change the needle--one that is correct for the fabric being sewed
check the needle plate and see if there are any burrs--if there
are gently use a small file to take off the burr
check with sewvacdoctor.com,,,or ,,a1sewingmachines.com
or sewusa.com about a manual,,, you'll have to call them or
email them about the manual..
the tenison dial may need to be replaced.
Dec 17, 2012 | Sewing Machines
Thread keeps breaking
Aug 17, 2012 | Singer Confidence 7469 Mechanical Sewing...
Needle wont stay threaded when sewing
have thread tails of 4 to 6 inches long & pull the thread back behind the needle before you start sewing
Mar 11, 2012 | Singer 4423 Sewing Machine
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Singer 1507 Logo
54 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
