Hi My tv is hard to turn on sometimes, and when it turns on then after some seconds or sometimes minutes, it turs off and remain on standby. Other times it turns on and runs ok for hours!!. Any help is welcome!! Thanks!!
    Sergeant:
    Champion:
  • 431 Answers
If you have a direct short circut such as diode zener fet trans. reg ic you would blow a fuse and it would never come on since it comes on and works you know there is nothing shorted now main descaler ic's can be intermittent due to heat but ck pwr supply first if all good ck regulators on logic board
Posted on Oct 07, 2010
    President:
  • 1,099 Answers
All you need to do is to open the back cover of the television to check for dry soldering and bulged capacitor, if found replace with appropriate parts.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
Good luck in solving the problem.....
Posted on Oct 04, 2010
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Sep 17, 2009 | Sony KP-44PX3 44" Rear Projection...
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture and tv automatically turns off
Good day.
You are getting an intermittent performance for your unit. One reason for this might be with the loose contacts on the high voltage section of your unit. Have it resoldered.
Regards,
chris
Aug 19, 2008 | Sony KP-48V90 TV
TV Lamp light blinking
COULD BE FAN NOT WORKING. TAKE BACK OFF SEE IF TURNING, CLEAN THEM. GO TO SONY.COM,TROUBLSHOOTING, OR SHUT THE TIMER OFF.
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Jul 10, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hi there. i have a Sharp tv (SX68RF8) which seems to turn off (go into stand-by mode) on its own after few minutes...sometimes it stays on longer sometimes it turns off in seconds..i always have to tur it...
Sounds like something is overheating or it is getting noisy power from the mains.
Try leaving it off for a while and point a fan at it, if it turns on and stays on for longer then it is obviously a thermal issue.
Such a problem would need to be addressed by a qualified factory trained repair technician.
May 02, 2008 | Televison & Video
Fix my tv
COULD BE FANS NOT WORKING. TAKE BACK OFF AND SEE IF TURNING, CLEAN THEM, OR TURN STAND BY MODE OFF OR GO TO SONY.COM, TROUBLESHOOTING OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
Dec 19, 2007 | Sony KV-32S42 32" TV
Troubleshoot-5 blinks red light front of TV
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
May 17, 2007 | Sony KP-51HW40 51" Rear Projection...
No picture on a Sony KV-32V65 TV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the Cboard, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking.
Jan 18, 2007 | Sony KV-32V65 TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
