Question about Dell Dimension 2400 PC Desktop
Speakers killed my moniter
When I plugged my new speakers into my dell cpu my screen cut off. I tried unplugging the speakers ut it didn't work. I even tried unplugging everything else, while resarting my cpu numerous times....nothing worked;my moniter still refuses to work
  • 30 Answers
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
Posted on May 27, 2008
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
My moniter has a knob for volume control with a green light to indicate that it's on, but I moved it in order to grab something behind it and now there is no sound at all. The moniter came with the Dell...
Try plugging in headphones into your computer. If they work then your audio circuit is working. You can also try running the diagnostics from the the Resource CD, It will have"Diagnostics and utilities" listed under the "Contents". You will have to bootfrom that CD disk. To do this, power on your computer and tap the keyto bring you to the "One time boot menu". Insert the CD and then select CD/DVDdrive and hit key. Selectthe "Run the 32 Bit Dell Diagnostics". Select "Custom Tests" and run the audiotest. If the audio tests fail you might have a problem with your speakers. The easiest and sure fire way to determine if your speakers are the problem is to try another set of speakers.
Feb 22, 2011 | Dell Dimension 4600 PC Desktop
This machine was running a 1.2 processor which I now know is the fastest processor the mobo will support. However, and before I knew this, I placed a 1.53 processor (AX1800DMT3C) in the slot and the bios...
The original CPU was 1200 Mhz, namely 12 times the 100 Mhz "clocking" supplied by the motherboard.
The new CPU is 1.53 Mhz, namely 11.5 times a 133 Mhz clocking, if the motherboard can supply that rate of clocking.
If your motherboard can only supply 100 Mhz clocking,
then the new CPU would run at 1150 Mhz (namely its 11.5 multiplier over the 100 Mhz clocking), i.e., slower than the original CPU.
Can you try the 1.2 processor in some other motherboard?
It's possible that you "killed" it, when you removed it,
or after you removed it, by giving it a static-electricity burst.
Do you have another processor that you can try in your motherboard?
What happens if you put the 1.53 processor into the motherboard?
Does it POST (Power On Self Test) ?
Sep 01, 2010 | Sony VAIO PCV-RX460 PC Desktop
DGM screen monitor problem ''22
the light blinking makes me think that the moniter is going in to sleep mode...try turning the computer on while the moniter is not pluged in(pull the blue vga cable) wait a bit then move the mouse around then plug the vga coble back in...(while the screen is already on)
Jul 09, 2010 | Computers & Internet
My dell diminsion 8300 will not turn on a flat screen monitor only turns on a old analog crt
could be the moniter has packed in try a freinds one and if it works its the moniter if it doesint then you need a new gfx card
Mar 12, 2010 | Dell Dimension 8300 PC Desktop
Dell 2350:when i push cpu button,the green light blinks for 1 second and cpu and moniter does not go on. same thing happenns with the moniter.
Reseat your memory card first. But unplug the unit first from power. Discharge your static by touching the bare metal case of your CPU before doing that.
Second try is to clean it using soft eraser the contact edge of it. Or have a good spare to test.
Sep 07, 2009 | ASUS A7V8X Motherboard
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
19 inch Dell Moniter Screen turns blank
i think may be its monitor problem or may be the wire problem that are attached with ur CPU...... change it and then see its again wrking??????
Mar 23, 2009 | Hitachi CM721F 19 in.CRT Conventional...
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Dell Dimension 2400 PC Desktop Logo
Alun Cox
