SOURCE: I am looking for a manual and troubleshooting
Look it up on the internet you should be able to find one. Try the www.astec.com website first.
SOURCE: got a astec sa302-3505 power supply . . . need to
Simple, Just connect a switch to Green wire and one of black wire.
When the green wire got connected with negative (Black wires are negative) the SMPS Fan starts which is also a visual feedback to you that SMPS starts.
----------------------O /
Grean /
-----------------------O
Black
So simple..
SOURCE: my astec atx202-3515 power supply
just flip it back to 115v hook it up and see if it works. if itdoesnt work replace it . I did that once it was fine the comp didnt turn on til i turned it back 115v
SOURCE: I need a data for the Astec SA302-3515 300-Watt
Everything you need to know can be found here:
http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php
(just copy and past the above link in your internet address bar in a new tab)
If your
power supply is rated 6 AMPS and your motor is rated 14 amps peek, then when
that motor starts it will draw the 14 AMPS, That will trip the power supply
right then and there. After it runs a few seconds the AMPS will drop about ½
that, but still 7 AMPS is more then the power supply is rated, so you will need
a different power supply.
