Hook up old tv antenna to converter box
The rabbit ears have no connector that fits the converter box. There are 3 wires attached to screws. How to attach antenna?
  • 2 more comments
  • pschemberger Jan 13, 2009
    no jacks in back of tv. How to connect?
  • ms mary Feb 19, 2009
    I have no antenna plug on my 30 plus Zenith with a rotary dial. Went to radio shack and purchased a matching transformer for connecting 75 ohm to 300 ohm and a new antenna to replace rabbit ears. I have 4 screws (2 - uhf , 2 - vhf) on the back of the tv. First it was suggest to use the uhf since digital uses higher channels. I never got the language screen, just a lot of snow. I then screwed the adapter to vhf, more snow no language screen. Someone suggested to use another balun so 1 for uhf, 1 for vhf and connect the 2 with a t-splitter to the converter box. At this point I am curious if will work. Any other suggestions, we like our retro TV it matches the 60s kitchen. Help!!!!!!
  • jmoshier Feb 20, 2009
    We have the same problem with our pre 80's tv. only screws in the back of the tv for the antenna. Only snow when hooked up to the hd converter box following the directions and use of a converter for the antenna hook up from radio shack. Are these tv's just to old to pick up the new signal?
How can i connect inside anntena to the tv and converter box?
Posted on Oct 16, 2009
You need one of these: http://www.tvconverterboxstore.com/servlet/the-271/digital-analog-converter-tv/Detail
Posted on Jun 12, 2009
How do you hook up a tv with just screws to a converter?
Posted on Feb 01, 2009
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
How to hook up T V ears on 32 " element tv ( elucfw329 )
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Jan 16, 2014 | Element Electronics FLX3210 32 in. LCD TV
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
How to hook converter box to rabbit ear TV
Hi, Sorry Vicki, Play Taps for the Relic. Those old tvs don't have the type of tuner that will even accept an input from a converter. The good news is there are quite a few good tvs out there that don't cost a fortune and you will really like the new picture they are capable of. Good Luck to you!
Mar 19, 2009 | Televison & Video
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Hooking up a convertor , when i have a vcr, dvd player
You can hook it up through the antennae system. Keep your dvr connected to the tv the way you had it. Hook up your TV rabbit ears antennae to the converter box in the connection on the left side of the box. Then hook up the antennae lead from the converter box to your TV on the right side connector. The only thing I'm wondering is, do you get stereo sound this way and does anyone know how to get it without hooking up the separate audio and video plugs? There aren't enough connections on the tv to hook up both sets.
Nov 12, 2008 | Zenith C27A24T 27" TV
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Feb 04, 2008 | Proton MM2701VT 27" TV
Televison & Video Logo
2,677 people viewed this question
Top Televison & Video Experts
Electro Med Services...
