Question about Samsung CLX 3160fn All-In-One Printer
Paper keeps jamming on Samsung CLX-3160 FN. How do I prevent this from happening?
    President:
  • 670 Answers
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Posted on Oct 04, 2010
Testimonial: "This solution worked for me. Thanks for the worthwhle advice!!"
  • jsledder Mar 08, 2011
    This tip saved me a 180 mile trip to take the machine back and exchange it. At $4.00/gal for fuel, THANK YOU!!!!
  • Stephen Lam Mar 08, 2011
    Glad I was able to same you both the time and money! Thanks for using Fixya!
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
Paper jam all the time
I've got the same problem but with envelopes. Every time I want to print envelopes the printer jams. It happens at least every 3rd or 4th envelope? Any suggestions? I wonder if I have the tray setup properly?
Jan 21, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My samsung CLX-3160 says "paper jam" and yet there is no paper jam
Open the back door, and inside at the top above the fuser there is a cover that will lift up. In front of the cover will be a spike.
Life the cover, and let the spike (a paper sensor) go into place under the cover and replace the cover and close the door, and it should work.
The spike is lifted as paper passes through.
If you ever lifted the spike while the cover was open and then closed the cover, the spike can't get back so is always lifted and it thinks there is always paper
Mar 11, 2010 | Samsung CLX-3160 All-In-One Laser Printer
I hv samsung 3160 fn & HP laserjet 1008 printers installed on one system.when i am commanding print to HP 1008 by selecting HP 1008 printer from all printer menu.my HP printer always blinking orange...
Just pull the ink toner and check there is not any paper jam also check in back side of printer for paper jam.
Refix toner cartrdge in its position.
Tehn check.
Jun 07, 2009 | Samsung CLX 3160fn All-In-One Printer
MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Scanner locked said my little screen of my printer Samsung CLX - 3160 FN
There should be a lock icon either on the side of your scanner or underneath the bed look for it and make sure its unlocked.
Mar 30, 2009 | Samsung CLX-3160 All-In-One Laser Printer
We have the samsung clx 3160 fn laser printer and the ink is really low and needs to be refilled. Is this something that we need to have a tech service it or can we do it ourselves, also how do we change...
You can buy toner cartridges to this machine and fix the problem yourselves. Go to any office supply store and they will have toner cartridges for the Samsung clx 3160. The display will flash the name fo the cartridge color that needs to be replaced. Just open the front door of the machine, pull out the empty cartridges and pop in the new ones.
Jan 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Double printing in my samsung 3160 fn
open your prtinter from backside then open fuser asenmbley.
u need to change your roller
but pls take support of technician.
Oct 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
926 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
