Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Top oven does not work...
The top oven does not work: once Iset the bake/broil temp. the main control board clicks but the temp. does not change: it stays @ 100 F. I noticed that the ignitor is not coming on. I troubleshooted the main board' output volts to dual valve - upper and lower bake - and upper broil - and it seems fine, there is voltage across to the ignitor too. I ohmmed the ignitor and it has "some" resistance ( I do not know what is the exact value), so then I replaced the upper ignitor and still the top oven/new ignitor do not work. At this point I am thinking to check the 'DUAL VALVE" that connects the ignitors. Any suggestions? Thanks for your help.
  • 2 more comments
  • forza_Inter May 27, 2008
  • forza_Inter May 28, 2008
    I did not check the continuity through the dual valve coils yet, but assuming those coils are both ok ( I don't know their specified resistance values..) then if the ignitor does not come on at all I have to believe that it is either a broken white (neutral) wire between the valve' coil and the neutral terminal, or loose connection at the neutral terminal. Apparently I did not see anything that looks like a " broken " wire...
  • forza_Inter May 29, 2008
    Thanks Mike, I am aware about not to try to supply 120V directly to the valves' coils and I do have the schematics. Thank you again for your support.
  • Anonymous Mar 22, 2014
    new spark igniter will not spark
    President:
  • 2,712 Answers
Check the valves to see if there is any gas discharge. If there isnt, it could be a blockage in the tubing or a defective valve..
Posted on May 27, 2008
  • 105 Answers
The thermostate which is responsible for cutting of temperature when it reaches preset temperature on the oven. Since ignitors are fine.
Thermostate sends signal about the present status of temerature to igniotor to work or whatever way it is required.
First you check the thermostat
  • 290 Answers
If the oven is wired properly and correct polarity on the outlet, here is the power flow.
Power will come from the control board relay, through the ignitor, then goes to ground through the dual valve.
The resistance of the ignitor causes it to heat up, the hotter it gets the more power goes to the valve. When the amp draw gets to about 3.2 amps there is enough power for the valve to open and let the gas into the burner.
It is unusual for both the bake and broil functions to fail at the same time. They are separate circuits. The dual valve is actually 2 separate coils inside one housing.
If you have continuity through the ignitors and continuity through the valve coils, check the wiring from the valve to ground. These should be the white wires that come from the valve and connected together before going on to the main neutral connection.
Let me know what you find.
Thanks, Mike
  • Michael  Lindley
    Michael Lindley May 29, 2008
    forza,
    I don't know what the resistance should be. I don't remember Maytag listing resistance specs in their tech sheets for anything, but the circuit is pretty simple. If you have power to the ignitor, a good ignitor, a complete circuit through the coil, and a good path to neutral, the ignitor should glow.
    A word of advice, do not try to put 120v to the valve to check it. The resistance of the ignitor cuts the voltage to the coil and if you put full 120v to it, it could burn out the coil. I found this out by experience.
    If you don't have the wiring diagram for the stove, you can go to sears.com, click on parts, enter the complete model number and view a parts breakdown and wiring information. You can also get schematics from servicematters.com. Click on the Maytag link and download the library and you can search by model number.
    Let me know if you have any questions.
    Thanks, Mike
    Sergeant:
    Champion:
  • 359 Answers
Sounds like a sensor prob
    Novelist:
    Scholar:
  • 148 Answers
There should be a temperature sensor controlling the flow of gas as a safety measure somewhere, like in a gas water heater. It would try to fire the starter and if it gets no flame it will kill the gas completely.
    President:
  • 1,314 Answers
Measure the resistance on the valve if you have continuity its good if not replace it
  • robert samples May 29, 2008
    id say your thinking is pretty much right on there is no resistance value for the valves your looking for continuity now other than that you have to look for amps and current draw on the valves im assuming you have the tech sheet if not e mail the model number to me ill send you one b4829@yahoo.com and im a real appliance repair tech not computers cell phones playstations or any of that junk
What would cause the broiler element to override the baking element? My oven has lost its mind. It doesn't matter what setting I use, The broil element takes over and burns everything. Please help.
Not 100% sure but my guess. Most electric ovens usually bake with both elements on. The bake element(bottom) is usually on at full power with 240 volts to it. The broil element(top) is usually on at 1/2 power 120 volts to help even out the temperature. My guess is your bottom element is not coming on at all either because it is burned out or something in the control system. So what is happening is the oven is trying to heat to the set temp with only the top element keeping it on much longer than it normally should be on and burning everything. Now if you set the oven for bake and the top is on red hot, you have a control system problem something like a bad selector switch or main control board if the oven has a electronic control.
Apr 10, 2015 | Ovens
My Kenmore model 950 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
Dec 28, 2014 | Kenmore Kitchen Ranges
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
226 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
