Question about Buck Honda Civic 2007+ Car Stereo Wire/wiring Harness Plug
Had a flat battery not got code for pioneer keh-1530
Wiring on pioneer car stereo
Red is ignition....yellow is battery or memory....black is ground....blue or blue w/white stripe is power ant or remote for amp...orange is illumination (may not need)...white/white with stripe is front left i believe...grey/grey w/stripoe is front right...purples and greens are rear
Jun 18, 2016 | Pioneer Car Audio & Video
I have a pioneer keh-p5400
You are not going to be able to find a new radio that will run a changer.
Nov 10, 2011 | Pioneer KEH-P5400 CD Changer
Im lookin for a Pioneer KEH P-6200 user manual downloadable or printable
You can download and print the instruction manual for Pioneer KEH P-6200 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 21, 2011 | Pioneer KEH-P6600 Cassette Player
I need an unlock code for my pioneer KEH-P4900 radio cassette player. Can anyone help?
pioneer does not have security codes. what is the problem with the radio.
Feb 06, 2011 | Pioneer KEH-P4900 Cassette Receiver
I need to connect the battery on my car, does the pioneer keh-p6020r have a built in security code?
If you are not sure, then try this
If you do not have the code (and you have NOT replaced your battery yet ) then you can protect your radio memory by either connecting your battery charger across the cables when you remove them from your battery OR buy one of these off Ebay (or make your own using a PP9 and a Cigar Lighter Lead.)
Ebay Search : CAR MEMORY SAVER
May 17, 2010 | Pioneer KEH-P6020R
Hi, I need a wiring diagram for a Pioneer KEH-P3630R Radio/Cassette system
s.gif Faisceau avec connecteurs ISO pour autoradio PIONEER 12 broches
NEUF SOUS BLISTER
16 broches sur ISO - Dimensions de la prise environ 43 x 8 mm
Détail des câbles des haut-parleurs :
Blanc : HP avant gauche +
Blanc/noir : HP avant gauche –
Gris : HP avant droit +
Gris/noir : HP avant droit –
Vert : HP arrière gauche +
Vert/noir : HP arrière gauche –
Violet : HP arrière droit +
Violet/noir : HP arrière droit -
Détail des câbles d'alimentation :
Jaune : Permanent + 12 V batterie
Rouge : Alimentation + 12 V après contact
Noir : Masse
Bleu : Antenne motorisée
cote_g_olitec_j.gif Liste des autoradios compatibles :
cote_g_olitec_j.gif Série KEH cote_d_olitec_j.gifKEH-1100SDK
KEH-1150SDK
KEH-1200SDK
KEH-1300K
KEH-1300R
KEH-1300SDK
KEH-1311
KEH-1400R
KEH-1400SDK
KEH-1450
KEH-1450R
KEH-1500
KEH-1500R
KEH-1530
KEH-1530R
KEH-1540
KEH-1700
KEH-1700R
KEH-1730
KEH-1730R
KEH-1800R
KEH-1830R
KEH-1900R
KEH-1930R
KEH-2100R
KEH-2300R
KEH-2400R
KEH-2500
KEH-2500R
KEH-2520R
KEH-2530R
KEH-2700R
KEH-2710R
KEH-2720R
KEH-2730R
KEH-3400
KEH-3520R
KEH-3700R
KEH-3710R
KEH-3720R
KEH-3730R
KEH-4400R
KEH-4500R
KEH-4530R
KEH-4700R
KEH-4730R
KEH-5700R
KEH-5730R
cote_g_olitec_j.gif Série KEH-P
cote_d_olitec_j.gifKEH-P26R
KEH-P27R
KEH-P28R
KEH-P2800 R
KEH-P2830R
KEH-P3300 R
KEH-P3400 R
KEH-P3600 R
KEH-P3630R
KEH-P3700R
KEH-P3730R
KEH-P4300R
KEH-P4400R
KEH-P4500R
KEH-P 4510
KEH-P4530R
KEH-P4600R
KEH-P4610R
KEH-P4630
KEH-P4630R
KEH-P4700R
KEH-P4730R
KEH-P5700R
KEH-P5730R
Jul 14, 2008 | Audio Players & Recorders
Buck Honda Civic 2007+ Car Stereo Wire/wiring Harness Plug Logo
107 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
