Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I am having same problems, what is deflection board-where located?
  • RCA Master
  • 5,138 Answers
Deflection Board is Bottom board to the left on the Right hand side is the SSB board/signal board cable/AV inputs.
Look for bad capaciotrs they will be Vented,swollen or puffed up on top. CP150 2200uf 16v use 25v CP114 CP120 are 220uf or 330uf 35v replace all 3 they will be in the same circuit. Resolder all the Pinns on the FBT flyback Transfomer.
Posted on Oct 04, 2010
I have a model D52W23 and I have taken the back off but still do not see the bulb location. I see circuit boards but no bulb at this time. Is it located behind the circuit boards?
that model doesnt have a bulb it has three picture tubes. Chances are YOUR needING a deflection board for that model its the large board on the left side. You can get replacement deflection board from www.tvrepairworld.com
Sep 19, 2011 | RCA D52W23 52" HDTV CRT TV
Power light blinks 3 times but it does not come on
Thats caused by issues on the deflection board. It can be the power caps CP150, CP120 and CP114 or it could also be the Flyback and HOT tarnsistor or several other items all located on the deflection board. Often its easiest to just replace the deflection board on that model. You can get the deflection board from www.tvcircuitboards.com
Jul 21, 2011 | RCA HD52W59 HDTV Projection Television
I have a rca 61" rear projection r61wh76. when i
That is normally caused by failed capacitors on the deflection board or also the flyback could be bad also located on the deflection board. Your board is the PSB260 deflection which is available from www.tvrepairworld.com
Jul 18, 2011 | RCA Televison & Video
I have a rca hd52w59 tv. turned it on this morning and it made a snowy noise in the back and shut off. what is the problem/ expensive to repair/
Most likely problem is the Flyback has shorted or CL031 has burned a hole through the deflection board both on the deflection board. Replaceing the deflection board is the best way to repair the issue. You can get replacement deflection boards for your model at www.tvrepairworld.com
Jun 14, 2011 | RCA HD52W59 HDTV Projection Television
Why does my tv keep going off after a few seconds if this is a overload relay where is it located at the back or front panel
Its very common for the deflection board to have problems and that will cause that type of issue. You can get deflection boards from www.tvcircuitboards.com
Jun 13, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My r61wh76 does not turn on. what could be the problem
With that model its common for the Deflection board to be the problem when it doesnt power up. It can be the Power caps, Flyback transformer or several other items all located on the deflection board, so its usually best to replace the deflection board . You can get the deflection board PSB-260 from www.tvrepairworld.com which comes with installation instructions.
Jun 13, 2011 | RCA R61WH76 61" HDTV
The tv wont turn on, the power button on the tv will light up then it will blink and shut off.
With that model its common for the Deflection board to be the problem when it doesnt power up. It can be the Power caps, Flyback transformer or several other items all located on the deflection board, so its usually best to replace the deflection board . You can get the deflection board from www.tvrepairworld.com which comes with installation instructions.
Where are the vertical deflection caps located
Check C421, C427 and C429. These capacitors are located nearby IC401. IC401 is mounted on a heatsink and has the following markings on the body LA78041
Feb 11, 2010 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
