Question about Savio Water Master Solids Handling Pond Pump 2050 Gph, Modelno. Wm2050
Can I get a replacement impeller for a Savio WMS2050 pump?
Savio 2220 trips gfi. this is the second pump to do this. when the first one did it, I replaced it. was told it could be rebuilt, but for only $50 more I could get a brand new one. But I cant keep...
I think you are chasing the wrong problem. A GFCI trips when current has found another path other then the feed wiring itself. It has found another path to earth that is conducting about 5 ma or more. I would suspect the wiring not the pump. If the insulation breaks down in the pump motor that would cause it to trip. The fault can be anywhere downstream from the breaker.
If you are not comfortable get an electrification and have him meg the pump motor to be sure where the problem is.
Oct 22, 2013 | Plumbing
I have a Savio 2220 waterfall pump that is acting up. I have been running the waterfall for 3 years without a problem. Recently the pump will run a short time and trip the gfci. After letting it sit for a...
It sounds like a seal has broken and water is getting inside, tripping the GFCI. it may be possible to get a new set of gaskets for the pump, but it is not really an easy thing to do. Three years if it runs all day is quite a lot of hours. You could try a local electric motor shop, and ask for an estimate.
Jul 23, 2011 | Savio Water Master Solids Handling Pump...
My gfi reset everytime the savio pump plugin
I am assuming when you say GFI you are meaning GFCI, Ground Fault Circuit Interruptor. If the pump is throwing the smaller breaker on th plug than the pump is more than likly drawing too many amps for the plug. Make sure the GFCI outlet is rated for the same number of amps as the pump. That is a good sized pump and when it kicks on it draws a lot of power.
Mar 18, 2010 | Savio Water Master Solids Handling Pump...
Pump buzzes but will not start
pressure switch or u have no water or the bottom end is burnt
Jan 01, 2010 | Savio Water Master Solids Handling Pump -...
What side of the skimmer does Filter Media get placed? We placed in on the side with the pump and it is getting caught in the pump causing it not to run.
You can clear this by opening the pump and running a high presure hose it to center of impeller and let it run out the lid hole, or take pump apart and rinse it out that way. once you have the pump running again mix your filter media in a bucket of water and pour it slowley into the top of your skimmer while your pump is running. slowley being the key word here.
Aug 16, 2009 | Savio Skimmerfilter Base Unit, Black Lid
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Apr 06, 2009 | Savio Water Master Solids Handling Pond...
Savio Water Master Solids Handling Pond Pump 2050 Gph, Modelno. Wm2050 Logo
51 people viewed this question
Top Savio Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Savio Garden Expert? Answer questions, earn points and help others
