Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I need a manual for a craftsman 3 gal air compressor it will not go over 40lb compression and has only been used 3 times in the last year in a half thats when i bought it could the oil being old or low prevent it from producing more presser
    Champion:
  • 248 Answers
Check regulator may just need adjustment
Posted on Oct 05, 2010
I need a repair manual for a craftsman air compressor model #919.164180.
Hi gregtrulu...
Go to the Sears direct website and you can chat with them,email them, or have them phone call you.
You will ask them about the user manual that you want for the 919.164180 compressor you have
Please take time to rate me
http://www.searspartsdirect.com/partsdirect/contactus.pd
Sep 11, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftsman 6.5 60 gal horz compressor.
i have the same piece of junk, iv rebuilt it 3 times in the past 5 years always a piston rod snapped and then it was running on only one. they are built like ****. anyhow I finely got smart and bought a cast iron pump thats not only quieter but puts out twice the volume of air in half the time. it took some work but it was well worth it costing under 200.00. the rebuild kit from sears will cost over 100 and it wont last. the one from sears is a direct drive pump and you will be told no one makes a direct bolt on but all it takes is cutting the aluminum housing away from the motor and welding a pin or bolt to the end of the shaft and putting a pully on it, you will also have to turn the motor to the side but let me tell you this was the best move i ever made. you can pick I bought my new pump from a place called heavy dudy air in ga. 877-447-2485
Oct 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
No air pressure
If your motor is running and the pressure is not building it is either the valve plate or the compression ring. Check both for damage.
Sep 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Mar 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Dec 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
208 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
