Question about Samsung SGH-D900 Cellular Phone
Main menu i want to get rid of the menu options from the front screen on my phone. this will enable me to access the shortcut options
    Brigadier General:
  • 7,752 Answers
Is it not easier to use your manual for this.....
Posted on Jun 03, 2008
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
IN THE MIDDLE OF MY MAIN SCREEN HAS JUST APPEARED A TAB SAYING 'NO EVENT' AND I CANT GET RID OF IT?
try this: hold it down for a few seconds and then a small garbage can should appear at the bottom, drag it to it OR try dragging it to like left side of the screen for it to go back into the main menu (sound like you accidently set it as a shortcut) otherwise you will have to do a hard reset which will set everything to default settings .. *2767*3855# (this code will erase everything)
Jun 29, 2010 | Samsung Jet S8000 Cell Phone
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
How do i set the ip address on a AR-405
Depending on the interface option set up in your copier, you will either access the printing setup options via the Custom Settings option, then enter the Key Operator access code to view the expanded menu or you can press the 'Copy' button to the left of the LCD screen and look for Main Menu options, then make sure you've enabled TCP/IP (You may have to reset the copier in order to enable it). You should be able to enter the IP address manually.
Sep 18, 2009 | Sharp AR-275 Copier
Street pilot 510 can't get rid of saftey mode ex-rental
Safety mode (prevents you from changing routes whilst in motion) is enabled disabled in the system options.
Found by navigating Setup (spanner at bottom of main screen) --> System --> Safe mode
Mar 01, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Nov 16, 2008 | LG RUMOR Cellular Phone
Nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
Shortcuts
you could always change the shortcut keys to something else. Thats the only way I know of as your shortcut keys can be used for most functions ie messages phone book media player and camera or what ever you want you should be able to change them 2 keys to something else
Jul 18, 2008 | Samsung SGH-D900 Cellular Phone
MP3 enabling
Step by step to enable mp3: Two part process. To enable outside phone buttons to play mp3: From main screen press OK and then the number 0 seven times (you?ll see a series of question marks disappear). Then scroll all the way down and press #11 (Music Setting). Finally, choose My mp3. To get MP3s to play, including ringtones ? Press OK (Menu) and go to Settings and Tools, press 5 (phone settings), press 2 (shortcut key), press 5 (play key), and choose my mp3s.
Jun 21, 2007 | LG VX8300 Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
