Question about Marantz Audio Players & Recorders
Took my Marantz 5025b to shop to replace belts, they also want to replace pinch rioller and idler tires, is that standard and do you know where I can get them, thanks
All belts and pinch roller should be replaced at one time.
Posted on Oct 20, 2011
  • Marantz Master
  • 5,259 Answers
All of them are prone to wear so it is good practice to replace them, even if the others don't need to be replaced.
Belts are not maker specfic, and can be found by just measuring the diameter in MM and entering it into Google. Rollers and Tires however are not universal. In some cases only the maker of the deck will be the only source of them.
Posted on Oct 07, 2010
How to replace idler pully
Go to harbor freight and buy a timing belt removal tool ($45). Remove the passenger tire and cover behind the tire. You should see the timing belt. Pull down on the idler pulley to remove the serpentine belt. The idler pulley should screw into place no problem. Took me about an hour and that includes 15 minutes BSing with the neighbor. I think you can find youtube videos on the serpentine belt removal which should help.
Jun 13, 2014 | 2005 Chrysler Town & Country
Tape deck repair
If the belts are replaced the unit may still need oil in the flywheel which should have been done when the belts were changed, or oil applied to the motor bearing or the motor itself might be done. You might need a new one- they do not last forever
Sep 30, 2013 | Marantz Audio Players & Recorders
Replacing a belt
Replacing the Drive Belt
IMPORTANT: To aid in reassembly, note the orientation
of the drive belt on the two idler pulleys and the engine
flywheel pulley prior to performing the following steps.
Refer to Figure 10.
The edger drive belt is subject to wear and should be
replaced if any signs of cracking, shredding or rotting
are present. To replace the belt, proceed as follows:
1. Working in front of the edger, loosen the flange
lock nut on top of frame, allowing the idler pulley
assembly to pivot slightly out from the frame. See
Figure 10.
2. With your other hand, carefully reach under the
rear of the unit and remove the belt from around the
engine flywheel pulley.
3. Remove the spindle sheaves belt guard by removing
the two self-tapping screws which secure it to the
blade plate assembly. See Figure 10.
4. Carefully remove the belt from the pulleys,
again making sure to note the orientation of the belt.
Discard the belt.
Install the replacement belt (Part No. 754-04032B) in the
same configuration that the original belt was routed as
follows:5. Working from the front of the edger, place the belt onto
the spindle sheaves, route it back onto the two idler
pulleys, and then place it onto the engine flywheel
pulley.
IMPORTANT: Make certain that the "V" side of the belt
is seated into the top pulley and the flat side of the belt is
seated into the bottom pulley.
6. Reinstall the spindle sheaves belt guard with the self
tapping screws removed earlier.
7. Make certain that the drive belt is on the engine
flywheel pulley and idler pulleys, and retighten the
flange lock nut on the top of the frame.
IMPORTANT: Make certain that the drive belt is seated
correctly and that it is riding smoothly on the spindle
sheaves and is not pinched between them. Repeat the
first three steps if the belt is pinched.
You don't want the belt pinched between those spindle sheaves...trust me ;)
the manual
Oct 13, 2012 | Troy-Bilt tb554 lawn edger
Which tools do I need to replace belts on Marantz 5025B Tape Deck. Can you help me with instructions on how to do it?
use dental tools. usually you can see the pulleys that the belt runs through. pretty easy fix.
Apr 08, 2011 | Audio Players & Recorders
Dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
May 28, 2009 | Kenmore Dryers
Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Feb 09, 2009 | Crosley Traveler Turntable
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Sony VCR
I'm not sure how old your unit is but over time, the rubber parts in a VCR become cracked, glazed and begin to slip.
There is a rubber wheel about the diameter of a nickel that is called the pincher wheel and does exactly what its called.
It pinches or compresses the tape against a shiny metal spindle called a capstan. The capstan spindle is connected to a motor. The pincher wheel rests against the turning capstan with the tape in between the wheel and capstan.
The pincher wheel can become glazed and coated with a brown oxide that has worn off of the tape. This causes the tape to slip and it can spool out into the VCR.
There is another wheel called an idler tire. It lays flat and pivots between the sending reel and pickup reel. Its used during play, fast forward & rewind. This wheel too can become glazed and worn causing slipping. If your unit won't play, fast forward or rewind, most likely the idler tire is the culprit.
There are also belts that can also become glazed and worn. These belts are used along with motors in the tape load/eject mechanism and capstan drive. If the belts slip, the tape may not load or eject properly and the capstan might not be turning properly.
When I owned my repair shop, one solution was we to remove the belts and/or tires and apply a re-grip solution on the rubber with a cotton swab, while roughly rubbing the the entire rubber surface back & forth with the swab. The re-grip solution actually eats away the top surface of the rubber leaving the rubber surface course and causing it to grip better.
Another solution was to just replace all of the rubber tires and belts. These parts including the re-grip solution may be ordered through www.mcmelectronics.com
Please let me know if I may be of further assistance to you.
- Jim
Feb 26, 2008 | Televison & Video
Rewind
Dear Tim, In all likelihood the belts of your VCR have become old and worn. I suggest you unplug the machine, and open the bottom plate. You will now be able to see the Drive belts. Go to a Spare parts shop and buy a Belts set for your nodel from them, and replace. Also, try changing the REW/FF Idler unit. This should do the trick.
Sep 28, 2007 | Panasonic PV-V4524 VCR
Rewind or fast forward
Though not familiar with this model, VCRs of all sorts have an idler mechanism which drives the supply and takeup spindles. Either the idler is somehow defective and slipping, and, assuming this idler is belt driven, the belt may be slipping just enough to cause a no Rew/FFW condition. If you had access to a test tape jig (a clear dummy tape, which allows a tech to view what is happening in the area normally obscured by the loaded tape), this might give a clue as to what is happening. On alot of machines, a problem with Rew/FFW would also mean a tape takeup problem in standard play, result in tape spilling out inside the machine. Sensors would catch this condition and go into a error mode, as yours is doing. One other thing which might be happening here, is the pinch roller not being disengaged from the capstan in the Rew/FFW modes. I think this is where I'd look first, and you can probably see if such is happening just by pulling the cover off the VCR. The pinch roller is just to the right of the rotating video head. In the play and forward/rev search modes it will press the tape up against the capstan (a rotating shaft). When in Rew/FFW, the pinch roller should be pulled back from the capstan, maybe 1/4 inch or so. Whatever the case, repair will likely take someone tech savvy. Costs might not be economically justified, with the low-cost, disposable rigs sold in the last 10+ years.
May 29, 2007 | Sanyo VWM-950 VHS VCR
392 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
