I recently moved, my computer tower was working fine before i moved it, and now it doesn't even turn on. i've tried different plugs and when i looked inside it, a green light is on, so it is apparently getting electricity
    Brigadier General:
  • 10,406 Answers
Do the fans inside the case spin?
If so, then the computer is getting power.
If you have an older computer, with a Pentium 2 or Pentium 3 CPU, it's possible that the "slot-mount" CPU has been dislodged from its "slot" socket. Turn the computer off. Disconnect the AC power.
Make sure that the CPU is properly "seated" into its socket.
Posted on Oct 04, 2010
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
My Acer Aspire M5100 get power but will not turn on
Does the CPU fan come on ?
Does the power lead that plugs into the cpu fan on the motherboard supply the required voltage ?
This one is a bit harder and once you check it you most likely need to apply thermal paste - but is there sufficient thermal paste between the CPU and the heat sink on the CPU ?
Does the power supply box in the tower case have its fan spinning when power on ?
Is the motherboard bent ?
I have seen this one - poor installation with different sized mounting screws. When motherboard gets hot the motherboard went faulty.
Some motherboards need a rubber insulator under the screw maybe there is a short under one of the mounting screws !
Mar 12, 2017 | Acer Aspire M5100 AM5100-U5313A AMD...
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
Xps 600 tower does not power up the monitor
The system will turn off if you hold down the power button for 10 secs. Can you check if other monitors work fine with this system?? (my best guess is - NO) since this monitor works well with other systems, the monitor being a failure is ruled out. So this boils down to a system failure & not a failed monitor. Worst case scenario this one must be a Motherboard & Power supply issue.
Jan 12, 2009 | Dell Microsoft Windows XP Home Edition
Signal Cable Problem
Check the monitor plug that goes to the computer for bent pins. or try another monitor/or cable .
Jan 12, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
