Question about Ovens
I have a Gaggenau oven, EB 965-610. My problem is that the vent fan stops working and the display panel and panel above the oven with the dials becomes very hot and starts to smell. I had this problem once and it required changing the mother board which was costly. Is this the only way of approaching this. It seems that it may be that a fan needs to be replaced.
  • 2,272 Answers
You need to check whether the fan stops just in few seconds or it stops after running for some time. if the fan stops after running for some time then:-- Its only the fan needs replacement to solve this issue.It happens because the fan motor is weakened and jammed up.This fans are not to be repaired so in that case you will have to replace the fan itself.
And if the fan stops immediately within seconds then:-- It indicates that the board has the issue and in that case the main board needs to be replaced.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 04, 2010
How do I set the time of day on a Gaggenau Wall Oven, EB 985611?
How do I set the time of day on a Gaggenau Wall Oven, EB 276-610?
Mar 08, 2011 | Gaggenau EB984 Electric Single Oven
How to take the door off a gaggenau eb 290 oven
gaggenau oven EB 378-6 door won't close completely It pops back open 2 inches.
Apr 23, 2010 | Gaggenau EB290 Electric Single Oven
Changing from C to F temperature on Gaggenau EB
your oven has no ability to change from celcius to fahrenheit here is the link to the manual:
http://www.gaggenau.com/AP_en/products/product-detail.do?contentId=cc4fb38a-ea89-4593-a268-95ea093f9d3f
there might be a secret mode but only the manufacturer might know that.
all dealers are in other countries.
Sorry I could not resolve this issue for you.
Feb 14, 2010 | Gaggenau Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau eb 270
No you don't need to remove the oven door to change the cover of the display. You have to remove the whole unit out and remove the top lid. Don't forget to switch off the circuit breaker before doing this and be careful this unit is heavy.
Jul 02, 2008 | Gaggenau EB 270/271 Electric Single Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Oven
go here
http://www.gaggenau.com/AE_en/Home.do
the customer support
then operation manual
Dec 04, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
201 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
