Question about Lexmark X8350 All-In-One InkJet Printer
Keeps saying tape still on cartridges and not aligned properly and there is not any tape on cartridges.
  • 44 Answers
Make sure that there is nothing stuck in the cartridge compartment, sometimes a little piece of dirt could give you a problem. Use small mirror if needed to look inside.
Posted on Oct 04, 2010
Testimonial: "I'll try checking that out. Thanks."
pagebor
  • 2785 Answers
SOURCE: Lexmark X7350 alignment problem
you can check the old cartridge for reference
Posted on May 19, 2008
fgainer
  • 54 Answers
SOURCE: dell 922 printer alignment problem after refilling cartridge
Sounds like the cartridge ink jets have dried up. Try running a cleaning on them to see if you can unclog them. If this fails to work try gently rubbing the ink jets with a Qtip and alcohol. If this doesn't work for you then you will need to purchase new cartridges.
Posted on Feb 02, 2009
  • 514 Answers
SOURCE: photo 924 keeps saying alignment problem. please remove tape from
""I have the same issue. I replaced both cartridges and ran the alignment test numerous times but kept getting this message. I then unplugged the printer and plugged it back in and it was fixed! You probably already tried this but if not, it worked for me. Good luck!""
try that for about 10 seconds per the manual at ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it)
good luck!
Posted on Feb 28, 2009
marketex
  • 371 Answers
SOURCE: Printer says tape hasn't been removed. Won't align
1. Remove the cartridges from the printer.
2. Turn the printer off. Disconnect the printer from your system.
3. Disconnect the printer from the power source.
4. Examine the cartridges for any remaining tape or tape adhesive.
5. Use a can of Compressed Air to blow out of the printer, any loose bits of paper or other foreign matter.
6. When you have done all the above, reconnect the power source and reconnect the printer to your
system.
7.Reinstall the Cartridges.
8. Retry the alignment routines.
9. should the same result you first experienced reoccur, repeat steps 1,2,& 3 and repackage printer for
shipment to your vendor, service vendor, or Dell.
Posted on Apr 09, 2009
efs_perpends
  • 1996 Answers
SOURCE: Alignment problem- says to remove tape from
Did you recently install new ink cartridges?
See below, or go here and enter your model # , choose tech support and search "change print cartridge" for detailed instructions with pictures.
Overview
This article provides general instructions on how to change the cartridges on Lexmark Inkjet and All-In-One printers.
Procedure
1 Ensure the All-In-One printer is powered on. No image.
2 Lift the scanner unit or access door (per right-hand image).
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
6b The image at right illustrates inserting the black cartridge.
7 Close the carrier lids so that they remain closed. See image above in Step 3. No image.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers ID: ENUS32244 Overview
Procedure
NOTE: These instructions are general, and your specific Inkjet or All-In-One may appear different than the pictures below; however, the steps are the same.
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2 Lift the scanner unit or access door (per right-hand image).
pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. pattlnk_1202009_209-hw_cartridge_carrier_lids_p.gif 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5 Remove the protective tape from the back and bottom of the new cartridge(s).
pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge. pattlnk_1202009_2024-color_install.gif 6b The image at right illustrates inserting the black cartridge. pattlnk_1202009_2016-black_install.gif 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image. Still Need Help? If you require additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need the machine/model type and serial number (SN) of your printer.
Please call from near the computer and printer in case the technician asks you to perform a task on one or both of these devices.
Posted on Jul 28, 2009
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
My lexmark x 5650 keeps saying alignment error, try to remove tape. I've done this multiple times, tried cleaning the cartridge, and it keeps saying alignment problem. ive unplugged and plugged back in...
alignment error usually means that one cartridge is not printing, or paper tray is empty.
try removing both cartridges then stamp each printhead on some folded tissue paper. You should get one solid strip of black ink with the black cart and 3 colour strips with the colour cart.
If you don't...there is your problem.
good luck
LC1000
www.inkbank.com.au
Dec 01, 2010 | Office Equipment & Supplies
My lexmark z1420 cant print the alignment page, it keeps saying that the protective tape may still be on the cartridges, but it isn't, I've tried putting different cartridges in (the old ones) and it is...
The cartridges may not be seated properly in the carrier or just needs cleaning. Remove the cartridges from the printer. Close the cover of the printer. Unplug the printer from the power source and leave it unplug for now. Here's a link to the Lexmark website to guide you on how to manually clean the nozzles of the cartridges. http://bit.ly/9ZpYd1 . On the page, there are also other instructions on how to maintain the cartridges using the Lexmark software but that's applicable once you have resolved the alignment problem. Plug the printer back to the power source. Once printer's ready, re-insert the cartridges.
Mar 31, 2010 | Lexmark Z1420 Printer
I have lexmark x6170 and error message says remove tape on ink cartridges and there is no tape.says align error
Hi. The cartridges may not be seated properly or just needs cleaning. Remove the cartridges from the printer. Close the cover. Grab a damp paper towel and place it on the table. Set the cartridge on it with the nozzles facing down. Draw about 2-3 lines in one direction to wipe clean the nozzles. Do the same to the other cartridge. Unplug the printer from the power source for about 10-15 seconds before you plug it back in. When the printer's ready, reload the cartridges. Let it print the alignment page. Hope this fixes the problem.
Mar 19, 2010 | Lexmark Office Equipment & Supplies
Alignment
you have to be really careful with thermal printers they tend to break very easily...
  1. make sure you have the printer in the right outlet
  2. the sheet is aligned properly
  3. you have'nt shredded an electric wire tape
  4. and last make sure you haven't over heated a sensor
Good luck
if u need any more help feel free to pm me
May 25, 2009 | HP Officejet 5510 All-In-One Thermal...
system.
Apr 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
Align Print Cartridges
A simple question first - have you removed the protective tape from the bottom of the cartridges? What kind of printer is it? I suggest you unplug the printer for a few minutes and then try again. Are they the manufacturer's cartridges or a lower cost brand? If they are the latter, it's possible they won't work with your printer.
Aug 05, 2008 | Tablets & eReaders
May 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
281 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
