Question about Kenmore Elite Oasis 27052 Top Load Washer
Fills with water then won't go to the wash cycle until you slam the lid several times
    President:
  • 670 Answers
It sounds like the lid switch is faulty. The washer has a lid switch that checks to see if the lid is open, if lid is open the washer will not start the wash cycle. Check/replace the lid switch and you should be back in business.
Posted on Oct 04, 2010
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
STOPS IN MIDDLE OF CYCLE, HAVE TO OPEN LID AND SLAM IT TO COMPLETE CYCLE. ALSO AGITATOR DOESN'T SPIN WHEN WATER IS IN TUB.
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: You do not have to drain the washer to complete this repair. Once the lid switch is adjusted or replaced, the water will drain. This will save you time in having to bail water.
PS Slamming the lid switch is not recommended. This will actually break the switch or bow the lid and make the problem worse over time.
Jul 06, 2009 | Washing Machines
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not go pass the wash cycle to spin or drain
There is at least one safety switch activated by the lid.
Depending on machine construction, these are somewhat exposed to water incursion that eventually causes them to fail.
The slamming of the lid is causing the failing switch to make enough contact to allow it to spin.
If you are lucky (I don't know your machine), these may be located toward the rear of the housing where they can be fairly easily replaced.
Jul 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Cycle stops...
replace the lid switch, or check the connections it might even be your pusing rod for activating the switch
Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washer
Sounds like the lid switch to me .... cheers and merry Xmas from 'downunder'
Dec 24, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Nov 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite Oasis 27052 Top Load Washer Logo
168 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
