Question about Cobra CPI 1000 DC to AC Power Inverter
I have a Cobra HG PI 2000 that has burned out two water kettles and a TV. The current seems to "Pulse"\r\nAny thoughts??
3 Suggested Answers
  • 32 Answers
SOURCE: Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Posted on Aug 15, 2009
maxmrossi
SOURCE: Need Cobra 148GTL with Cobra HG M75 pin-out color code
The above wiring combination does not work
Posted on Sep 16, 2012
I am a woman of 66 years old with a blood pressure reading of 110/60 and a pulse rate of 70. Is this normal?
there is no such thing as normal but an average for your health
see your doctor and get what he considers an average from your past records and use that average as a guide for your readings
Feb 25, 2017 | Health & Beauty
I have a cobra hg m73 mic and the wire broke.i dont know the pin color code
it depends on what kind of radio youre using and how many wires are in the mic cord
Apr 06, 2013 | Cobra Highgear 70 Hg M73 Standard Dynamic...
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
How do you set the timing on a 1981 honda goldwing gl1100? it does not have points!
There is no timing adjustment , the pulse generator can only be installed in one position. Perhaps the vacuum advance mechanism under the pulse generator is the source of whatever problem you are having. Make sure the vacuum line going to vacuum advance is not cracked or leaking and that vacuum advance itself still working correctly. Applying vacuum to the advance, the base plate should start moving at 1.6 in. Hg (40 mm Hg) and stop moving at 3.2 in. HG (80 mm Hg).
Oct 29, 2010 | Honda GL 1100 Gold Wing Motorcycles
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
Jul 03, 2009 | Cobra HG-M75 Microphone
Can kettle be cleaned and continue to be used.
I use a solution of vinegar and water (1:1) and boil it in the kettle, to remove mineral deposits from the metal heating surface (We do the same with the percolating coffee maker and run it through several times)... It seems to take any residual tastes out of the unit and possibly also cleans the plastic parts that it touches (I believe it does).
By the way... WHO thought it was a good idea to heat apple cider in an electric kettle. Sorry but WOW
Feb 24, 2009 | General (102105011) Electric Kettle
Kettle keeps Turning off and on.
Try descaling the kettle for about an hour with some white vinegar without heating. Hopefully the problem is caused by limescale on the thermostat/thermocouple and this will cure it. If this doesn't seem to help then probably the thermostat/thermocouple is to blame, and although easy to replace, it seems that the best way to get the right bits is an authorised tefal dealer. This link will get you the user manual for your kettle if you need it; http://www.t-fal.ca/tefal/products/product/index.asp?univers%5Fid=400&dept%5Fid=430&sku=L00056&mscssid=JXT37R7ERWKH9P2URRA8CLM0SHMF327C Also it has the contacts for tefal customer service(Canada) if you need. Hope the descaling helps, it usually does the trick :)
Mar 21, 2007 | Tefal Elegance Brushed Chrome Cordless...
Cobra CPI 1000 DC to AC Power Inverter Logo
60 people viewed this question
Top Cobra Electronics - Others Experts
Gil Shultz
cwradio73
Bill Boyd
Are you a Cobra Electronics - Other Expert? Answer questions, earn points and help others
