Question about Cycling
How do I switch Schrader to Presta using my Schwinn Aluminum Frame Pump
    Problem Solver:
  • 10 Answers
If your pump only has one hole for the valve either one should fit in. If it has two than the Presta fits in the smaller one. Hope that helps.
Posted on Oct 07, 2010
My innertube leaks air and i am no familiar with the air intake device on it
There are two kinds of valve on bicycle tubes, Presta and Schrader. You are probably more familiar with Schrader because this is the type used on cars and most bikes. And I am guessing that you have Presta on this bike (Presta is skinnier than Schrader, and it has a little nut that you unscrew, where Schrader has a spring inside it. Google images for "Presta Schrader" and you will see both kinds, and you will also see a little screw-on adaptor that you can use on a Presta to make it fit your pump or air-hose like a Schrader. You can buy these adapters on-line or at any bike store. Good luck!
Oct 03, 2012 | Fuji Bicycles Cross Comp
How to use a Schwinn Aluminum Frame Pump to pump up a bike tire??? I have it on the tire but the air comes out of the top piece instead of the part hooked to the tire!
THE TRICK TO SWITCHING OVER THE OUTLET FOR THE PUMPED AIR IS BACK PRESSURE. IF WHAT YOU ARE FILLING IS COMPLETELY FLAT, BLOW INTO THE FITTING YOU WANT TO USE AND IT WILL SWITCH OVER.
Sep 05, 2011 | Schwinn Bicycle Aluminum Frame Pump
I purchased a Schwinn bicycle pump, but I'm having trouble determining how to use it to inflate my standard bike tires. The instructions that came with the pump assume that I know the name of the type...
There are only two types - presta and schrader. If the instructions named them you could just Google them for descriptions and all kinds of other answers. The schrader is what we think of as the automotive style.
http://en.wikipedia.org/wiki/Presta_valve
http://en.wikipedia.org/wiki/Schrader_valve
Back to the search engines, "how to..." usually finds answers, such as "how to inflate a presta valve tube".
http://www.terratrike.com/media/documents/PrestaValve.pdf
http://www.youtube.com/watch?v=wreZho5I2E4
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Wheels_and_Tires/Inflating_Tires
Aug 02, 2011 | Schwinn Cycling
I can't seem to use this on my bicycle tires. what am I doing wrong?
What kind of valve do you have on your bicycle tires - standard (like a car) or Presta (narrow with manual screw down valve)? If you unscrew the head of the pump you should be able to reverse the rubber gasket to fit each type - wide for standard and narrow for Presta.
Jun 03, 2011 | Schwinn Bicycle Aluminum Frame Pump
How do i use the schwinn airdriver 1100 pump
This pump is a bit strange to use. The valve in the filler head is odd in that it controls the flow of air in both direction...which is not a great design in my opinion...but it does allow for use in different filling applications. The trick is getting the pump into its different filling "modes"
For a Schrader bike valve:
1. Make sure the pump is in "tire mode" by blowing into the valve with your mouth. If you then pump the handle you should feel air filling your mouth.
2. Put the "locking lever" in the unlocked position, the unlocked position is when the silver metal lever is parallel to the air hose, or said another way it makes an "L" with the air outlet that goes on the tire air filling stem. To verify this is correct, look in the air outlet and move the lever from locked to un-locked, you will see slight change in the diameter of the outlet.
3. Push the air filler hole over the schrader valve really hard and make sure it is seated all the way down. Close the "locking lever" (silver metal lever should now be perpendicular to the air house and be in line with the air outlet... i.e. point straight out away from the tire filler stem.
4. Pump.
For a Presta bike valve:
1. Make sure the pump is in "tire mode" again.
2. Take off plastic caps off presta valves on bike tire.
3. Unscrew the little nut on the presta stem to allow the tire valve to open when pressure is applied (you can test this by pushing the stem in a little and air should escape, the nut holds the valve closed, so it needs to be loosened).
4. Take the adapter from the locking lever (silver metal lever) on the pump and screw it on the presta valve. The adapter is the brass looking thing. Screw the rubber gasketed side down on the presta valve.
5. Press the air pump tire filler outlet onto the adapter.
6. Close the locking lever to seal the filler head on the adapter.
7. Pump.
8. Unlock the locking lever and pull it off quickly.
9. Unscrew the presta adapter and screw down the presta valve nut but just finger tight.
10. Screw on the plastic cover cap for the presta valve.
To Fill a Ball:
1. Twist the ball pin filler out by rotating the gray plastic tab around until the ball pin filler is pointing straight out (in-line with the air hose).
2. Make sure the pump is in "Ball mode" by again blowing into the filler. Sometimes shaking the filler valve really hard is necessary.
3. Put the filler pin into a ball.
4. Pump.
Hope this helps.
Apr 27, 2011 | Schwinn Cycling
How do you use the schwinn bicycle aluminum frame pump?
Do you have a presta or schrader valve on you bike tube? A schrader is a standard valve, presta has a little nut that has to be loosened to add air. Your pump has both heads or adaptors (I don't know which model you have). You should have instructions with your pump to explain how to use it, if not go to www.ehow.com and you can read all of the instructions, no use me repeating what you can read on your own.
Jan 04, 2011 | Schwinn Bicycle Aluminum Frame Pump
How do you fill the tires on this bike. The valve stems are not typical bike tire stems. I am (obviously) a novice biker and have not owned a bike in several years. The pump I bought is a Schwinn pump...
There are two types of valve stems, schrader ( like the valve stems on your car ) and presta. See images on this page http://www.sheldonbrown.com/brandt/presta-schrader.html Since you are asking I assume you have presta valves. You can get an adapter to convert the presta valves for use with a schrader pump. Unscrew the small knurled nut on top of the presta valve to open it, press down and release the small top to ensure the valve is free to move. Snug up the top when it is full.
Dec 23, 2010 | Schwinn Midmoor 700c Men's Hybrid Bicycle
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
Can't get this pump to work on either schrader or presta valves! Help!
Its probably the fact that there are two separate holes for presta anad schrader, if so put your finger over the one you want to use and give small pump to vent it then attach, if not then you have to screw off the cover and invert the inner rubber core for presta or schrader, can you give me more details or pic...
Mar 26, 2010 | Cycling
Cycling Logo
89 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
