Question about Yamaha Full-Size Keyboard
I need to replace the XW199 board in a Yamaha P80 keyboard. Can you give me a price for the part?
    Problem Solver:
  • 11 Answers
$50.00
Posted on Jan 09, 2015
I need a new a new board
Yamaha XM199 for a P80
Posted on Apr 06, 2011
  • NIKONIK10 May 17, 2011
    did you find an answer to your request?
    I need the same....
  • prensner6 Nov 03, 2014
    I took my board to a ex military radio guy and he showed me where I needed to soldier and I did and it works great
My Yamaha electric piano, P80, will not power up
first - check the power supply if it's really giving power.
Get voltmeter or plug it to something else you know it's working.
If you are sure it does and still nothing, you need to check the fuse inside the P80. I've been there, it's not so hard to open it
(from below of course)
BTW, it's advisable to user surge protector on such delicate devices like computers and keyboards if there are any fuses that have blown. I can't tell you how many times a blown fuse has stopped equipment from working. I had a blown fuse go in a microwave oven a few years back. I called a repair guy while on a job to fix my Leslie (many years ago) and the culprit, a blown fuse. I could have fied it myself if I had given it more thought.
Check the internal fuses first and you might save some money and a trip to a repair center. , sometimes a fuse can look good even when it is blown. If you have a voltage tester do a continuity check on the fuse just to be certain.It's possible that the P80 does not use internal fuses especially since it uses an external 12 volt power pack There might be info on the fuse in the P80 manual. Otherwise try Yamaha support. A lot of low volage gear run of AC adaptors is unfused.
Another possibility is that the power connector or switch on the P80 is broken. DC power jacks are liable to get broken solder joints due to movement, especially if they are circuit board mounted and not chassis mounted. If you know what you are doing test the connector and switch with a multimeter.
If they are good then also check the wires from the switch to the main board. They a probably connected with a plug, which itself can come lose.
You can test for bad connections with the power off. Only test with the power on if you really do know what you are doing! You won't electrocute yourself but you can easily damage the keyboard if you are not careful.
Unless you are experienced in electronics repair that is as far as you should go.
Oct 23, 2017 | Yamaha Music
Dgx 230 dc in connector bad
This type of keyboard is well know for the power socket breaking away from the main PCB. You will need to unscrew lots of screws to reveal the circuit board with the power socket on. If you look closely at the solder side you will probably see that the track that the socket is soldered to has broken. Simply link the solder joint to the circuit further along the track by bridging between socket and next point along the track. You may need to replace the socket if it has become damaged. If you can use a soldering iron it is fairly easy but if in doubt contact a repairer.
If you need a socket Google :
Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
Jan 25, 2013 | Yamaha Keyboard w/ 76 Graded Action Piano...
L am looking for PSR 620.yamaha keyboard.it is a musical instrument. l want to get the manual.
http://music.manualsonline.com/manuals/mfg/yamaha/psr620.html there you go please give me some thumbs up!
May 10, 2011 | Yamaha PSRS550B Workstation PSR-S550B...
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
Yamaha Motif 6 froze, tried re-booting screen is stuck on the initial page "Now Checking plug-in board..." Also unplugged the keyboard.
This is a long shot... If you have an add-in option board it may have become dislodged from the socket. If you move your keyboard this may be what happened. In any case it needs to be opened and look for loose cables, board, OR if you have a hard drive, the drive may have failed. The software in these units isn't smart enough to give the user any details of the failure/hangup.
Dec 04, 2010 | Yamaha Motif Music Production Synthesizer
Yamaha P80 broken DC input jack
Probably the jack is still OK but broken from the circuit board.
If it is OK, one needs to use a bit of epoxy to hold it in the correct place and solder jumper wires to replace the EXPECTED broken circuit board traces.
The jacks are readily available, often at Radio Shack or for certain at Digikey.com should the connector be mechanically damaged rather than just seperated from the circuit board.
Apr 22, 2010 | Yamaha Music
Yamaha keyboard not working
We have a Yamaha keyboard YPT-330 note E and F sharp not working why?
Feb 25, 2010 | Yamaha Music
Yamaha PSR keyboard won't power up
Unfortunately, I only have schematics for PSS-560 and PSS-570. If I remember correctly,with the parts side facing up, there should be a parts orientation printed on the circuit board. It will look like 2 black bars side by side with one of the black bars thicker than the other. If you got an exact replacement with the correct pin out the metal piece on the part that the black piece is mounted to with the 3 pins facing down towards the parts side of the circuit board should line put with the black bar lines on the circuit board. I hope this makes sense. Please get back to me. I had one of these keyboards laying around in my parts bin but stripped it because all the keys were broken and as they come in one strip asnd have to be ordered specially, I didn't bother keeping it. I may still have the circuit board somewhere.
Apr 15, 2009 | Yamaha Music
Yamaha Full-Size Keyboard Logo
389 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
