Question about MSI : P4MAM2-V (7095-010) Prescott/Socket478/VIA VT8751A/FSB533/DDR266/A&V&L/MATX Motherborad (MOT83) Motherboard
2 components knocked off
What a klutz, I destroyed 2 components on my mother board, they measure out to be capacitors (because of the charge and discharge charactoristics) not positive what the values could be stamped on top are these: 10 16S. A75 there are only 2 of these on the board, could you possibly help in identifying them or directing me to a schematic? They are in the corner by the PCI slots. Thanks Tom
tom1360@sbcglobal.net
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like power di'os are shot, prombally better get a new mother board
Posted on May 28, 2008
Bad capacitors Nichicon UHN1C821MPP
Um... capacitors aren't measured in MOhms (resistance or impedance), they're measured in uF (microfarads of capacitance).
Brand is of nearly no importance (you can use Nichicon, Rubycon, Sprague, any decent brand), but the uF rating and the voltage rating MUST match the originals - do NOT try to use an antirely different capacitor, it can destroy other parts (like rectifiers or power transformers), or burn PC traces right off the board.
Nov 05, 2013 | AOR Radio Communications
LG LCD TV clicking on and off no picture
check the capacitor(s) and replace the power components. Easy fix if handy with soldering electronics as you may need to replace capacitor(s), hopefully not mother board. Tv repairman should charge about $75-100.00 dollars for fix ...
Sep 21, 2012 | LG 42LC2D 42 in. LCD HDTV
Tv clixs on and off
check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Sep 21, 2012 | Sanyo 42 in. LCD TV
Horizontal transistor all damage in few hours after replace
Dear Sir:
Please review your schematic T.V, any component around from Horizontal transistor can destroy it.because is in Short Circuit, use your DVOM for isolate the components, measure the resistance, continuity ,and test for transistor, capacitor, resistor, diode, etc. 2) You must shure if the replace is the same caractheristic from the original.
Otherwise, the componente can not be result.
You can download the schematic from www. retrevo.com
sincerely. God bless you
May 05, 2012 | Sanyo Television CRT TV 27in * AVM300U...
Hi, I bought a Vizio L32 HDTV10A that didn't power-up. There were charred components on the power board (an 8-pin IC with heatsink and 2 resistors). I replaced the power board, and the power LED then...
change the mother board. the ic took a hit after the power board went off. it will test good without stress, but under power stress it break down. measure the output with osciloscope to check the waves you should get a saw tooth wave if the the ic is good under stress.
Mar 07, 2017 | Televison & Video
I HAVE A DELL INSPIRON 6000 SERVICE TAG HN98T61. THE AC POWER SUPPLY WELL NOT CHARGE THE BATTERY NOR WILL IT POWER THE LAP TOP. THE CHARGE LITE DOES NOT COME ON. I AM SURE OF THE AC POWER SUPPLY IS OK. IF...
Take a multimeter, and measure the VOLTAGE and AMPERAGE being emitted by the AC power-supply. If "none", or much less than the ratings printed on the label, then it's time to replace the power-supply.
Otherwise, it most-likely is the connector where the AC adapter is plugged-in to the motherboard that is not transmitting, i.e., electrically-disconnected from the motherboard.
Maybe, resoldering the leads from the socket to the motherboard will fix the problem. Or, take the laptop to a qualified technician, for proper repair.
Oct 17, 2010 | Dell Inspiron 6000 Notebook
Motherboard of my T3958 E-machine was destroyed by a power surge. Want to replace it with a stronger more effiecient one, but don't know the measurements of the first one.
simply replace it with a motherboard of micro ATX form factor. that should fit most system chasis. Most mother boards these days come in that size
Sep 26, 2009 | E-Machines Computers & Internet
Power led goes on and then goes off.
Some years ago I had a similar issue with an IBM and with that one the capacitor that filters out the current (right after the power jack, usually the very first capacitor that gets the power) was short circuited. It was a ceramical capacitor, at least that's how we call them here.
Apr 19, 2009 | HP Pavilion dv6000z PC Notebook
I have a 37inch insignia
Some people I contacted said it has faulty capacitors that need to be relaced. Available at radio shack.
Most likely causes in order:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
To replace capacitors:
  1. Keep yourself "grounded" when working with the circuit board. Static electricity will destroy electronic components.
  2. When replacing the Capacitors, press them "down" onto the circuit board as far as they will go, hold them down, solder into place and clip the excess terminal lengths flush with solder. Only by doing this will the metal shield (little silver box) slide down and over the circuit board during re-assembly. There is not a lot of clearance when doing this, as the 105C Capacitors are slightly longer that the originals. With minimal effort everything does fit back together.
  3. Use ONLY 105º C capacitors with a voltage rating of 35 V.
  4. Re-insert the DM circuit board into the Mother board; press virmly and ensure a proper seat of the DM board. Next, slide the metal case down and over the DM circuit board.
Jan 17, 2009 | Insignia IS-LCDTV32 32 in. Television
MSI : P4MAM2-V (7095-010) Prescott/Socket478/VIA VT8751A/FSB533/DDR266/A&V&L/MATX Motherborad (MOT83) Motherboard Logo
61 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
