Question about Brother IntelliFax-4100e Fax
The fax recieved is real light all the way down in the center of the page, can bareley read it.
    Scholar:
  • 159 Answers
More than likely this is a problem with the DR400 drum. As a technician I could easy find out by using a used replacement drum. Unfortunately, this would be expensive for you to always carry a spare drum. However, if you do have one used, keep it for checking. I suspect the drum only if this machine has lots of use, it just isn't up to it.
Posted on Oct 06, 2010
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Apr 26, 2010 | Canon FaxPhone L75 Plain Paper Laser
I have the Panasonic KX-FL511 and when we receive faxes we can not read down the center of the page. Does this need a new drum?
yes but try cleaning corona wire first, clean corona wires Gently with a #2 pencil eraser, then try making a copy again
Jul 09, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
RECIEVED FAXES ARE TO LIGHT TO READ
take drum unit out, and locate blue tab on bottom of drum unit. take the tab and slide back and forth several times, making sure you return tab to the same side it was on. then, locate the small **** glass that covers your laser, which is located on the bottom of the machine right under where your drum would be, and clean that with a cloth and alcohol or windex. if that doesn't help, your drum may be worn out.
hth,
razors
Apr 02, 2009 | Brother IntelliFAX 2800 Laser Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Black lines on received faxes
look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Can recieve well, sends all black
    The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
    Feb 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
    Brother IntelliFax-4100e Fax Logo
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
