Question about NEC Mitsubishi MGE 4000 Generator ROU Recoil Starter-Voltage Regulation:AVR. Fr
NGE4000J26 230-50 7911 2900 This part is burned. I
NGE4000J26 230-50 7911 2900 This part is burned. I need new like this part. Could You help me?  Mikä on hinta?
  • 1 more comment
  • heikki_riikk Oct 08, 2010
    Hi!
    MGE 4000 generator sr.no 1009432. Rotor was burned . I want a new one, when the price is
    good.
    Thank You very much!
    Hi!
    I`m writing from Finland!
  • heikki_riikk Oct 09, 2010
    HI!
    I found in Finland price to rotor. It is 1500 €. I must buy new generator.
    Thank You very much !
    Heikki
  • 3,740 Answers
If you are certain that is the part number you need (none of the MGE 4000 manuals) I have even list that number) you can contact Mitsubish at the number below for parts. It would help if we knew what country you were in to maybe find a closer source.
Mitsubishi Generators and Pumps Division is closed.
For Parts and Service, please contact Mitsubishi Engine North America, Inc
Ph 630-268-0750 Fax 630-268-9293
Thanks for choosing FixYa.
Kelly
Posted on Oct 08, 2010
  • 2 more comments
  • Kelly
    Kelly Oct 08, 2010
    I checked all 4000 ROU / REU units for this number US and Canada. No luck.
    http://www.mitsubishi-generators.com/par...
    http://www.mitsubishi-generators.com/pdf... No joy.
    What are we replacing?
    Kelly
  • Kelly
    Kelly Oct 08, 2010
    I am hitting dead ends on the search but will keep trying to locate something in Europe. The rotor part number I am seeing is KYG020001800
    In the mean time you can make a send to PARTS DEPT via email at Mitsubishi Engine North America, Inc
    Using this link below. Tell them you are in Finland and your looking for an MGE4000REU / ROU rotor in Europe. Also mention you additionally would like to know the replacement cost INCLUDING shipping.
    http://www.mitsubishi-engine.com/REV/d/i...
    I have to be totally honest I too have a generator (Robin) and my rotor failed. When I finally found out what the cost of the rotor was including international shipping it was the cost was abut 65 % of unit replacment cost. That was with me doing all the labor. I resorted to having the rotor rewound at and eletrical re-winding shop for about 40 % of the total unit replacemnt cost. It turned out to be a wise decision as it is still working just fine today
    Kelly
  • Kelly
    Kelly Oct 08, 2010
    There are a few places in Europe all of them seem to need you to contact them via email
    http://www.mitsubishi-diesel.de/start_en...
    This one says to ask for "Paul"
    http://www.meetens.co.uk/company/contact...
    This is the best I can do from here. I can not tell you any pricing. I wish I could do more but it seems Mitsubishi is not doing anyone any favors for customer support on line. I have spent about 3 hours just finding this information for you.
    Kelly
  • Kelly
    Kelly Oct 09, 2010
    Before you totally give up on your rotor... Just so you know there is a VARISTOR inside your generator rotor that fails. Sometimes it is just the varistor that has failed and not the winding. You have to be creative and cut into the plastic end of the bad rotor (bearing end) to locate the varistor. There is also a diode. Either one of these can fail causing the rotor to fail. I have often cut this open... replaced the diode and the varistor with parts from an electronics store and had the rotor perform perfectly.
    What youhave to make sure is that the rotor winding does NOT read from the soldered point to the metal armature. If you read no resistance then you can do as stated above. The hole that you make by cutting away the plastic is filled with blue epoxy and allowed to dry for at least 3 hours before installation.
    Because a diode is soldered to the coil ends at
    the terminals, resistance may be measured only
    when tester probes touche the terminals in one
    combination of polarity. Therefore, if no resistance
    reading appears, try checking in reverse polarity
    Your rotor should read 1.77 Ohms resistance.
    Just trying to save you buying a new generator. Your choices are: see if the old rotor is repairable by cutting into the plastic, replace the rotor or the generator. I note you stated you needed a new generator.
    FYI Robin Generators (inverter type are awesome) I would recomend either the RGV 4100 or the RGV 6100 (230VAC only 50 or 60 Hz). The RGV 6101 or 4101 are 120 / 230 VAC generators if you decide to go shopping for a new generator. Electric start models are RGE....vs RGV. Having said that.. I am not aware of the brands available to you in Finland. Use the above recommendations
    for comparison shopping.
    Take care,
    Kelly
    Take care,
    Kelly
1999 mazda 626 fuse 40A
cause burn out and overheat..??? If you put a new fuse in twice and it is still popping fuse you've got a dead short in the wires somewhere. Find out what the fuse controls and start there. Not gonna be fun.
Jun 11, 2012 | 1999 Mazda 626
Seems like my car has oil burning, need new Manifold. I would like to know why my car burning this much oil; is there a Manufature recall on these two items?
If there is blue smoke coming out the tail pipe it is burning oil. If there is not blue smoke then it's not burning it would be leaking. And have you checked the oil level? Are you adding oil? if it has smoke in the engine compartment then it could be a intake manifold seal but need more information to help you.
Sep 15, 2010 | 2003 Nissan Altima
Whenever I try to burn a disc on Pinnacle 12 Ultimate the burn fails. Then it tells me that I need to use an empty or re-writable dvd. I then used an empty re writable dvd and still the burn failed, and it...
The new Pinnacle Studio 12 includes more than 25 new features and more than a ... This is an upgrade. so you need Pinnacle studio 11 first. ...... could you tell me if u have tried that on a different computer with out ..... of data of the Pacific and burn it then because a compact disc and then the ...
thepiratebay.org/.../Pinnacle_Studio_12_Ultimate_-_by_Mick_(Full_Version)
Jul 18, 2010 | Pinnacle Studio Ultimate 12 for PC
Replaced belt, new belt is burning when pump engages
hi i have the same washer and i can't figure out how to change the belt. please help. anthonylombardojr@hotmail.com
May 10, 2010 | Amana Washing Machines
Im trying to copy text from ms word and burn it to dvd with no luck i have downloaded various softwarw programmes but still no good .please help
Once you copy (text, picture etc) from any file, You need to paste it somewhere before you can burn it. Once you copy something, computer holds it on something called a clipboard till you paste it to another document. This new document can be a notepad or another word file. So, once the copy is done, open note pad or an MS office new file and paste it on to that. Save this new file with any name (abc.txt or abc.doc for example). Now you can burn it to a CD or DVD. To burn, open the CD burning software. Start new data project, drag abc.doc or abc.txt file to the window at the bottom. click burn.
Mar 21, 2010 | Computers & Internet
Dvd doesn't burn
Hello there:
In order to burn any cd you first need a program to burn with.
roxio is one of the better burning studios that is out their. if your computer is new i would suggest refering to the users manual for further assistance the program may all ready be loaded on the computer. ok?
best regards mike
Aug 15, 2009 | LG (GSA4167BB) DVD RW Dual Layer Burner
Can't burn Cds on Itunes
This program is helpful for burning pretty much anything.
Since I got this I don't use anything else.
If it persists even after this program, you may need a new CD/DVD burner.
Jul 11, 2009 | Apple iTunes
Cooling fan
you need to check the fan motor. check the voltage of the fan while the engine is good and hott
Sep 28, 2008 | 1998 Chevrolet Camaro
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
Computer windows media
are you shure it isnt recognizing the unit? if it appears in my pc where you can see some of your hardware like the disk drives it means it is recognized.. and what you need is a program to burn the stuff into cds..
here is a free opensource software that will help you burn stuff into cds
http://infrarecorder.sourceforge.net/
hopes that helped
Dec 06, 2007 | Computers & Internet
NEC Mitsubishi MGE 4000 Generator ROU Recoil Starter-Voltage Regulation:AVR. Fr Logo
167 people viewed this question
Top NEC Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a NEC Electrical Supply Expert? Answer questions, earn points and help others
