Question about Fisher and Paykel DG05 Gas Dryer
The dryer drum makes noice - Fisher and Paykel DG05 Gas Dryer
  • Fisher and P... Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Posted on Oct 05, 2010
Load noice when drying
The squeaking is likely coming from the drum rollers and the grinding is likely coming from the drum rubbing against the door frame. This can be caused by a badly worn roller or damaged felt slide. A repairable condition that should be considered before throwing out your dryer. You can obtain a kit for this at your local appliance parts store or order on line. If you or know of someone that is pretty handy, you can install the kit, and a new felt slide for less than 1/3 the cost of replacing your dryer. Remember to inspect the drive belt to ensure that it is not torn or about to break.
Mar 03, 2014 | Dryers
I was instaling cabinets and steped on the top of the dryer and now dryer makes noice when turning
you bent the top and now its hitting the drum screws...take it off and re-dent it the opposite way
Apr 13, 2010 | Dryers
There is a squealing noice as the the drum turns. It does'nt make the noice all the time but at least 3/4 of the time. It seems to get louder the longer the dryer runs.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Dryer- Model #YLEQ5000PW0, does not get hot enough to dry clothes and makes a ckicking noice when the drum rotates. What do you think the problem is?
if you have any heat than your element is good,the reason it take's so long to dry the clothe's is due to a blockage,first you nead to look behind the dryer with out moving it to see if the vent hose is pinched off,next try running the dryer with out the vent hose hooked up,if it dry's well than you have a blockage some were between were the vent hose hook's up to the dryer and vent outside.you nead to check the roller's for the clicking noice.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Maks thumping noice
Replace the rear drum roller supports.
Jul 08, 2009 | Whirlpool Dryers
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Mar 22, 2009 | Amana NDE2335AY Electric Dryer
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Fisher and Paykel DG05 Gas Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
