Question about Fellowes (98904) Mouse
How do you sync this mouse? - Fellowes (98904) Mouse
Why won't this gearhead keyboard connect
google your keyboard model, there is a sync button somewhere , some how.
press the helpful button and follow me on fixya
How to Install Wireless Keyboard and Mouse
Re syncing my wireless Keyboard Mouse
Microsoft Hardware
How to Connect Wireless Keyboard to PC
Feb 04, 2016 | Computers & Internet
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
Used my wireless mouse yesterday morning and then couldn't work in the evening.
I think that you should change the battery of the mouse or could be that the sync is not there anymore. Try syncing the mouse again by pressing the sync button at the bottom of it for 10-15 seconds.
Admin
HNetworking.com
Feb 03, 2011 | Logitech Cordless Mouse
How can I re-sync the mouse to the computer?
Just press the sync button on the mouse and also the usb reciever, usually it works best if you press the reciever first then the mouse.
Oct 23, 2010 | Belkin DBF8E825USB Mouse
Cant get my wireless mouse to work
1. Press the sync button on the reciever (the only button on the reciever)
2. When the light blinks, press the sync button on the mouse (the button you are talking about on the mouse is a sync button, not a reset button, there is no reset button on the mouse), after you press the sync button on the mouse, the blinking will stop and will remain steady
Please post your feedback and Vote if the proble resolved as per your satisfaction.
Aug 17, 2010 | HP Wireless Optical Mouse
My hp wireless mouse does not work and i cannot sync it to my PC. the wireless keyboard works fine and i am able to sync it. how do i fix my mouse problem?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Nov 25, 2009 | HP Wireless Optical Mouse
I need to connect my mouse
There should be a tiny sync button on the mouse and the USB receiver that connects to your computer. Make sure your computer is on and loaded, then connect the USB receiver, and make sure the batteries are functional in the mouse. Once it's set up, simply press the sync button on the receiver, then press the sync button on the mouse and wait for it to sync up.
If your wireless adapter is bluetooth, you'll have to install the software that came with your mouse, and use the software to synch the mouse.
May 05, 2009 | Dynex Wireless Optical Mouse
Wireless optical mouse light does not blink
possible solution, is replacing the batteries. if the sync light blinks we round up with a battery problem but if not. its going to need a replacement i hope that helped. hit me back.
Apr 30, 2009 | GE Wireless Optical Mouse
My driver is not instolled
You don't need a driver for this mouse. I've tried downloading some. Just try syncing it with the laptop. On the base of the mouse, there is a red reset button. Press that, while simultaneously pressing the black reset button on the base of the charger. The laser light should becomes steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
May 18, 2008 | Targus PAWM001U Mouse
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Fellowes (98904) Mouse Logo
47 people viewed this question
Top Fellowes Computers & Internet Experts
Gary Paul
Level 1 Expert
ray gallant
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
