Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
I have an older desktop Dell computer and it turns on for a sec thenthe screen goes black you can still se it faintly. I was told it might be a capasitor but I opened it and checked the inverter and see no capacitors leaking or bulging. What can be wrong with this thing?
    Brigadier General:
  • 10,406 Answers
How did you check the inverter?
If you get a "very-dark" image, then the most-likely cause is a non-functioning inverter.
Buy a replacement (on eBay????) and install it.
Posted on Oct 04, 2010
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell Inspiron One 19 Black screen after dell logo boot up
Sounds like you have a video driver issue. See if you can boot from your "Dell Resource" CD or any other bootable CD disk. Power on the computer and tap the F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" into the CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If the computer boots from the CD drive then you Operating System Software is the problem.
Mar 19, 2013 | Dell Inspiron One 19 All-in-One Desktop PC...
My 1905FP Dell monitor powers up and the screen is normal for about 3 - 5 seconds and then goes black. Turn it off and then on and the screen goes thru the same routine as many times as you want to turn...
si al encenderlo dura unos cuantos segundos encendido y luego se apaga
revisa los condensadores en la fuente del alto voltage casi siempre se inchan y no dan el voltage correcto tambien podria ser una de las lamparas se quema el cable negativo de la lampara que es el mas delgado donde solda con ella.
Aug 16, 2011 | Dell UltraSharp 1905FP LCD Monitor
ACER screen goes black after a few minutes of being on. I then close the laptop then log on again and the screen comes on then flickers off back to black, can very faintly see the desktop in the back...
Hi. This might be an LCD issue or connector inside th LCD from the motherboard is loose. You may try troubleshooting the issue first before you send the computer for repair. This process will drain the remain electrostatic energy to your motherboard which sometime causing the issue. Please follow troubleshooting steps below.
Take out the battery and unplugged the power adapter
Press and hold the pwoer buttong for 30 secs
Put everything back in
Power ON the computer
have a good one!
Jul 29, 2010 | Aspire Acer 7520-5071 Notebook
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
My monitor do not work right
Are you saying that you can faintly see your desktop or just the reflection of your desktop??
if you are saying you can faintly see your desktop it means that the fluorescent light isn't firing up properly, take it to a repairman or if its under warranty, take it back for a swap or a refund.
Mar 24, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Black screen on start up
big bucks lol bad mobo usally the video is on the mobo so it would all hav eto be repleced or power resiters re solider in wich is tuff best sell it for parts on ebay get 200 or so toward new oen
Feb 01, 2008 | Dell Inspiron 2600 Notebook
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
78 people viewed this question
Alun Cox
