Question about Motorola Mobility L6 Cellular Phone
No display Battery cover was missing. Phone would turn itself off. New battery cover installed but; in the meantime - the phone works but the display went out. Black screen only. Everything else appears fine.
Musica
Posted on Jun 03, 2008
How to reprogram my sony ericsson k800i
Instructions
Obtain the unlock code for your K800i if the phone is locked. You can get the code from an unlocking service, or from the carrier that originally sold the phone.
Turn off the K800i and turn the phone over.
Remove the battery cover by sliding it toward the bottom of the phone. Lift the battery from the bottom and set the battery cover and battery aside.
Remove the old SIM card by sliding it out from under the metal clip. If you have an unlocked K800i, all you need to do is insert the SIM card from your new carrier. Otherwise, leave the SIM out and reinstall the battery and battery cover.
Turn the phone on and wait for it to boot up.
Press left on the navigation pad and press "*" twice, then press the left arrow again. The phone will display "Personalize with MNC2."
Type the unlock code and wait for the phone to reboot.
Turn the phone off and insert the new SIM card.
Jul 22, 2012 | Sony Ericsson K800i Cellular Phone
Tip
How to replace a Samsung SCH-U550 cell phone battery
The Samsung SCH-U550 is an older-style flip phone that doesn't see much use today. If you still have an SCH-U550 and you need to replace its battery, here's how.
First it's a good idea to turn the phone off. (You don't have to, but there's less chance of data being corrupted if you do.) Hold down the End button for a couple of seconds until you see the phone start to power down, then the screen will go black.
Once the phone is off, turn it over so you're looking at the back side. Most of the back cover, from the bottom about 2/3 of the way up toward the top, is one piece. To remove the cover, push down on it with your thumb and slide it downward. If you press on it closer to the top it will be easier to slide, but you may have to push firmly.
With the cover off, you should be staring at the battery. It's black and rectangular, and it probably says "Samsung" on it. Remove the battery by sliding your thumb into the groove on the bottom side and lifting it up.
When installing the new battery, slide it in from the bottom up -- towards the three gold pins sticking out of the phone. Those pins should line up with the three gold contacts on the battery itself. The battery will also probably have an arrow on it, in the direction that you should slide it.
With the new battery in, reattach the rear cover. There are three tabs sticking out of the top of the cover that will line up with three notches in the back side of the phone. Insert the tabs about halfway into the notches, then push the cover down (toward the phone) and slide the tabs the rest of the way in to snap the cover into place.
Now just turn your phone on to verify that the new battery works. If your phone doesn't turn on, remove the battery and reinstall it, being certain that the contacts and pins are touching and that everything fits into place.
on Jan 18, 2011 | Samsung SCH-u550 Cellular Phone
Nokia 6310i turns itself off
TRY REPLACING A NEW BATTERY .IF U FEEL THERE IS AN ISSUE WITH AN EXISTING BATTERY. ELSE GET THE FIRMWARE REINSTALLED USING NOKIA PC SUITE DATA CABLE AND MUST HAVE A HIGH SPEED INTERNET.
Feb 24, 2010 | Cell Phones
How to unfreeze samsung a736
Well first of all you can just remove the battery from your phone, the battery is located on the back side of your phone, Remove the back cover of the cell phone. Some Samsung phones have a plastic outer cover over the battery, while on other models the back of the phone is the back of the battery itself. Locate the release button or slider on the back of the phone. Depending on the Samsung phone model, the back cover or battery itself will slide downward or lift off when the release button is pressed or the slider is pushed upward.
Just insert the battery after 30 seconds, and then turn on your phone. hope this helps. Please post comment if further you have the same problem.
Good Luck!!
Thanks
Jan 12, 2010 | Cell Phones
Puk code
  1. Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
  2. Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  3. Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  4. Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  5. See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  6. Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
Sep 24, 2009 | Cell Phones
LG Rumour takes longer to turn on everytime it is turned off
My name is Tim and I am collection Specialist with Verizon Wireless, I see a lot of phones with problems but not any like this. This phone has truly seen its better days. Take it to a store and have them replace it with a different LG Rumor phone. IF you don't have Total Equipment Protection on your plan, then you are still covered under warranty for the 1 year or 2 year depending on the manufacturer warranty. But if you have Total Equipment Protection then your warranty is good for the life of the contract and you DO NOT have to pay the 50 dollar deposit, replacement should be free. If the Verizon Store is closed by you then call Verizon from a landline phone or another cell phone and they can get one to you within 2 days using priority shipping. If you don't have Verizon, then contact your service provider and speak to their customer service team.
Apr 05, 2009 | LG RUMOR Cellular Phone
Sony ericsson w910i
take the cover off remove the battery leave it for about 10 seconds, in the meantime clean the battery contacts then reinsert the battery and turn it on, think its had a build up of static and that sometimes stops the phone from switching on
Feb 12, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Poweron the lg shine
Seem you mobile phone battery is not working well try to get some one with the same mobile phone and change the battery and see if this works or else if you mobile phone has a warrenty go and claim it .if your that battery thing dosn't work then it mighy be the serious problem with your mobile phone
Sep 14, 2007 | LG Shine KE970 Cellular Phone
Phone dropped in water
Water + Phone = BAD ! Your phone is most likely damaged beyond repair if its been out for a swim. It sounds like its got some corrosion inside, when its turning off by itself. Most water-hazards is to costly to repair in comparison to getting a new phone, so your phone might work for now, but it wont get any better with time. The switch on the back-cover can be repaired with som super-glue and a little handy-work. Allthough if its the switch on the phone itself you've got a problem, since its soldered in. Then you need to take the phone in for repairs by a pro.
Aug 29, 2007 | Sony Ericsson K750
My Samsung SYNC got a little wet. Now it just says "download" on the display.
Follow these steps to get out of this problem......
  1. Takeout the battery.
  2. Leave your phone in free air for a day or two with back cover and battery removed along with Sim card.
  3. Put the battery back in phone and see if it works,else buy a new battery and follow above steps again before putting new battery in phone.
Thank you...!
Aug 02, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
