Question about Garden
Do you have a parts manual for a Lawn Genie model 54000 (previously RJ11)?
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 | Garden
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Carriage assembly is broken. need a new one
The replacement carriage can be ordered either through a retailer that carries this brand or from the manufacturers or a distributors website. If you have the owners manual it may list the part number otherwise you can look it up using the model number
Jan 11, 2014 | Genie Company Garage Door Parts Genie Gwkp...
Lawn sprinkler does not completely shut off but continues to flow barely noticeable!
Inside the valve is a seat and a rubber disc that closes it off. Chances are there's either debris on the rubber or it has rotted, causing a little bit of water to flow past the opening. There's a diaphragm assembly kit for it for less than ten dollars at your local sprinkler or irrigation store. To replace it you have to shut the water pressure off to the valve, unscrew the screws holding the top to the body, then remove the top and diaphragm assy. Be careful to not lose the spring on the top of the diaphragm. Once it's open and parts removed, it may be necessary to flush the valve. To do that turn the main pressure on for a moment and all the water (and possible debris) will shoot out the top. Be careful as this can be quite a gusher. Think "Old Faithful"
Then, making sure the seat (round opening in the bottom of the valve) is clean and free from debris, place the new diaphragm assembly, with the spring on top, into the body making sure it sits square. Then replace the top, or bonnet, and carefully screw the screws back into the holes. I say carefully because the screws are stainless steel and the body is plastic and will strip easily. Only tighten them snug, then about an eighth of a turn, in a star pattern so as not to warp the bonnet. When you turn the pressure back on you'll see if you did it correctly when there are no leaks. If there are little jets of water shooting from the side then you can gently tighten the corresponding screws.
Sep 07, 2013 | Lawn Genie 54000 3/4 Anti-Siphon Valve
The lawn sprinkler does not shut off but continues running just enough to be noticeable!
The valve is not seating properly. Should either be rebuilt using the same valve exchange the internal parts or replace the valve. You can try just replacing the solenoid but, rarely is this the problem.
Disassemble ames model 2398200 water genie
I have removed all screws and opened circular sides. I am unable to pry can apart. The hose is off the reel and one part is loose inside. I believe it is the hose guide. Any ideas? Next step garbage can and I won't be buying products made in China again! Thanks
Nov 12, 2012 | Ames 2398200 True Temper Water Genie Hose...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
