Question about Dishwashers
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
    Genius:
  • 1,122 Answers
Pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
Posted on May 28, 2008
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 | Dishwashers
Blocked hotpoint dwf 33
There is a drain hose for your dishwasher and it often gets clogged. remove and clean it , reinstall and problem solved. If this doesnt fixya then might have to throw parts at it. Not sure though without cleaning the hose first. Good luck
Jul 13, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Pumps in and out but does not wash
is the drain to far down the stan pipe or is the pip low down so just flows out hope this helps.
Feb 24, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Dwf 33
Took sides off to have a look.
Then turned on (but didn't touch!!) and was still making noise but no water. Lifted the float switch up and down and the water then started to come into machine. Drained machine and started it up again a few times to check wasn't a fluke and all seems well again!!! I was virtually on the point of giving in and buying new one as its 8 years old but hurray! not going to be that broke this month!! Husband will be pleased.
Sep 04, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 | Dishwashers
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
318 people viewed this question
Top Dishwashers Experts
