I have the wii and i have an error code51330 - Computers & Internet
Non of the above worked after 3 years we binned it & bought an x box connected as soon as power was added Nintendo are really poor machines - one day they will go out of business
Posted on Dec 24, 2012
    Novelist:
  • 108 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console, using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
For any further clarification, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Posted on Oct 04, 2010
  • jhbv Dec 24, 2012
    Non of the above worked after 3 years OF TRYING we binned it & bought an x box connected as soon as power was added Nintendo are really poor machines - one day they will go out of business
I try to connect to the internet and get error code51330
If this is for a Wii system then It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
Sep 08, 2011 | Computers & Internet
Can't connect WII to netflix. Ger error code51330
This error usually indicates that the WEP key you set on your Wii is not the correct one to gain access to your router.
When you setup a router for wireless internet, you usually set a WEP key. This is basically a security key(password) that you set so any device that wants to use your internet, has to enter correctly.
If you know your router security key, go into your Wii network settings and make sure it is entered correctly. I wrote a article on how to configure your Wii for internet. Click here to read it.
If you do not know the security key of your router, then read my other article by clicking here. This article will go over how to find the router security key.
Let me know if you have any questions.
Regards,
G33k
Jun 14, 2011 | Nintendo Wii Console
Will not connect error code51330
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=lang
Jan 23, 2011 | Nintendo Wii Console
Error code51330 trying to set up wi for internet
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
    1. Click here to go to our Wireless Router lookup page.
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
Aug 04, 2010 | Nintendo Wii Console
Error code 32017 keeps coming up on my wii console. i can still connect to the internet on my wii and play games but whenever i put in super smash bros it requires a system update. it will begin but never...
Error Code: 32017 There appears to be an issue with updating your Wii console.
  1. Try and perform another Wii System Update on your Wii console (how to).
  2. If you attempt another Wii System Update and still receive this error code, please call 1-800-255-3700 so that we may assist you further.
Mar 03, 2010 | Nintendo Wii Console
Cannot connect to the internet
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Jan 31, 2010 | Nintendo Wii Console
Wii won't connect to Internet. Error code is 051330
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 25, 2008 | Nintendo Wii Console
NINTENDO WII
Try this link it's nintendo's tech support:
www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Or this slightly less helpful database of errors:
www.wiierror.com/
May 06, 2008 | Nintendo Wii Console
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
