When I put black paper or envelope in the printer - it claims there is no paper -
    Brigadier General:
  • 10,406 Answers
The optical sensor is trying to reflect light itself, to the paper/envelope, and back to the sensor.
When no light reflects back, it claims "no paper".
Try a different colour of envelope/paper.
Or, determine in which corner of the paper that the sensor is, and paint a small amount of "Liquid Paper" onto that corner of the envelope, and let it dry thoroughly.
Then, when the sensor is over that "white" corner, the light will reflect, and you'll be able to print.
Then, scrape-off the "Liquid Paper" (or "White-Out").
Posted on Oct 04, 2010
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
I am trying to print envelopes through the side feeder. It will feed the envelopes through but it doesn't print anything on them and it says error, that I need to change the paper setting to letter.
First you have to get the copier to know that you have envelopes in the bypass. Put envelopes in the bypass and use the paper select key to get the bypass selected. The display will prompt you to identify what size paper you have and using the right arrow a few times to get to COM10 or executive. Press OK for the copier to accept the correct size. If you're using the printer as you information source make sure the printer properties of the driver are set correctly and all should be good.
Apr 25, 2011 | Canon imageRUNNER 1023iF Black and White...
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
What is the maximum weight of paper can you put in the printer?
Plain paper (60 to 90 g/m2), heavy paper (91 to 163 g/m2), envelope
(Envelope DL, Envelope COM10, Envelope C5, Envelope
Monarch, Envelope B5), label sheet, transparency ((Black and white
printing only)
Jun 10, 2010 | HP Color LaserJet 2600n Printer
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Envelope back is dusted on front of envelope
All I can think of is to Check paper type on bypass is set correctly on printers operations panel.
Dec 07, 2007 | OKI C5100n Laser Printer
123 people viewed this question
k24674
jasbo
jasbo
