Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Heater comes on then goes off. Displays code 11 on control panel
    Novelist:
  • 126 Answers
Ignition failure. Gas on, flue pipe clear, look inside the stove when you try to start. You should see a arcing which is the iginter.
Tom
Posted on Oct 13, 2010
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    For Kenmore 7903019400 wall oven error code F 11, the touchpad/keyboard is the replacement part called the clock/timer? as clock/timer or range control panel are only parts listed? so which part is it
    F11 means a shorted button on the button board. This could actually be a shorted button, or it could be a bad connection to the embedded microprocessor. There is literally no way to tell without actually testing the unit. If the EOC module (electronic operator control) comes with a button pad, change them both out if you can't test them separately. Kenmore has other manufacturers make their equipment for them (frigidaire, whirlpool, electrolux, etc), so the generic equivalent board may be cheaper to buy somewhere else than sears. Your local appliance service center will know what parts fit what sears models. The model number you provided is useless to me. 25321842-21syibu3fgwpdxocjnkpw0ib-3-0.jpg
    Dec 14, 2014 | Kenmore Kitchen Ranges
    Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
    Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
    Jul 15, 2014 | Rinnai Heating & Cooling
    Tankless water heater displays error code
    Before calling service technician, copy following links for troubleshoot resources:
    http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
    Jul 16, 2012 | Rheem RTG-74PVN Indoor Natural Gas...
    I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
    Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
    www.howtolou.com/clean-a-burner -Lou
    Dec 10, 2010 | Rheem Tankless Hot Water Heater...
    Hi. My oven displays F7 in red and next to that
    HI. This f-7 is indicating that the touch pad is malfunctioning. Follow the procedure below to address further.
    Determine if the problem is with the Key Panel or Control by:
    1. Pushing CLEAR/OFF pad.
    2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
    If code recurs, problem is in the control. Replace control.
    If code does not recur, problem is with the Key Panel.
    NOTE( If your unit is equipped with an integrated touch pad, and control board, you will need to replace the entire control board in this case)
    Nov 02, 2009 | GE Ovens
    I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
    F7 stuck keypad
    Stuck keypad may mean relay is turned on.
    Determine if problem is with the Key Panel or Control by:
    Jul 30, 2009 | GE JTP45 Electric Double Oven
    Heater won't start error code 11
    I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
    Jun 15, 2008 | Rinnai Heating & Cooling
    Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
    123 people viewed this question
    Top Rinnai Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    vance jones
    Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
